blinking engine light and tcs light
Old Sep 26, 2009 | 06:46 PM
wkkinc2000's Avatar
i was driven on the 5 freeway an outta no where the engine light started blinking and the tcs light came on...now my car is kaen a sputter noise...it shakes the whole car...its like it sucked sumthin up an its gaspin for air....idk what to do=(
Old Sep 26, 2009 | 06:47 PM
jjashaa's Avatar
Avant Garde Wheels
open your hood and look for anything unusual.
did the check engine light stay on? get the code scanned.
Old Sep 26, 2009 | 07:11 PM
wkkinc2000's Avatar
^nah just the tcs light...the engine liight just blinks...
an under the hood the enging shakes more then usual...
Old Sep 26, 2009 | 07:12 PM
wkkinc2000's Avatar
would it have anything todo with taken off the resanator
Old Sep 26, 2009 | 11:15 PM
hANDYcaptd's Avatar
It's the Halladay season!
^ No, it shouldn't.
So you get no CEL when the car is stopped?
Old Sep 27, 2009 | 11:52 AM
wkkinc2000's Avatar
^no it keeps blinkin tell the car is off...but why would the TCS light come on an the CEL light
Old Sep 28, 2009 | 11:07 PM
wkkinc2000's Avatar
i got it scaned my valves were mis firing..so all it needed was a valve adjustment...thanks folks
Old Sep 29, 2009 | 01:44 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Your cylinders are misfireing..
It is a bad coil pack or maybee u need new plugs..
I had a coil pack go bad and my car shook really bad and i could not drive over like 50-60MPH or the car would feel like it would shake itself into pieces..
Check the CEL code the cylinders in type-s are
back
123
456
front
and they fire 1-4-2-5-3-6 so if you have a misfire in code 4-2-5 replace coil 4 first and go from there..Lemme know if this helps!
Old Sep 29, 2009 | 01:46 PM
StonedCL's Avatar
B A N N E D
No u do not need valve adjustement just a bad coil pack what where the exact code?
P0300 , po304? Please list the exact codes and I will let u know what to do so you do not waste $$$ cuz the dlr will try and rip u off..
YOU DO NOT NEED A VALVE ADJUSTMENT
U NEED A COIL PACK $50 from the DLR I got 4 for like $75 off Ebay..
I have a couple extra if u live in NJ i can help!
Old Oct 3, 2009 | 11:24 AM
wkkinc2000's Avatar
Well i did have a tune up not to long ago and they replaced all the plugs and the coil pack
when the problem happened again i took it back an my mechanic just suggested to get the valves adjusted
thank you so much for your help though personally i would have done it myself but my parents offerd to pay for a profesional to take care of it
but still thank you
mada51589
Jan 9, 2025 04:40 PM
BigJilm
Sep 21, 2015 08:32 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
