Bleeding brakes
Old Nov 4, 2013 | 05:55 PM
LandCruzer94's Avatar
Bleeding brakes
Can someone explain to me why the bleed procedure is different from the traditional furthest to the closest of the master cylinder logic? I tried this method making three rounds with a Motive power bleeder and my brake pedal is limp. It'll eventually firm up with a few pumps when parked but even leaving the driveway is impossible. I wanna make sure I have this order right before I waste another two quarts of expensive brake fluid. Thanks in advance.
Old Nov 4, 2013 | 07:14 PM
Turbonut's Avatar
Don't believe it makes much difference which is bled first.
Some people say farthest first, some say closest first, same a manufacturer's recommendations, some recommend closest, some farthest.
Old Nov 4, 2013 | 07:20 PM
acrdr's Avatar
Honda brakes are bled LF,RF,RR,LR
Old Nov 4, 2013 | 08:01 PM
I may have egg on my face with this one. I didn't realize you had to bleed both nipples on the brembos, that little snippet was hidden in the archives with a service manual scan. I'll try again and report.
Old Nov 7, 2013 | 06:45 AM
chrisd421's Avatar
I did a flush and did it fl to get the immediate junk out, the rr,tl,fr,fl, and no problem
Old Nov 7, 2013 | 08:12 AM
Ccvn0's Avatar
The far away from the master cylinder is the one that you have to bleed first.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
polish_pat
Sep 30, 2015 12:22 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
