Big problem replacing parking brake shoes
Old Apr 6, 2014 | 10:38 AM
NCTL05's Avatar
Middle Finger anyone?
So I decided to replace my rear rotors and my parking brake shoes since I was in there. The brand of rotor and shoes were both wearever from advance auto. I got the rotor off and replaced the shoes, but for the life of me I can't get the new rotor back on. The parking brake is down and I took apart my console and loosened the adjusting nut all the way. I have the adjuster at the shoes adjusted all the way down too. I made sure that the tensioner pins are turned the right way. I tried to put my old rotor back on and it has the same issues, so I don't think the new rotor is the problem.
I understand that the new shoes might be a little thicker, but I can't even force the new rotor over them when everything is adjust down.
I am going to try to put the old shoes back on and see if that works. But I need to know if anyone else has had a similar issue or if I might have missed something?
Old Apr 6, 2014 | 10:43 AM
ak20eg's Avatar
ive ran into this problem myself. some of the shoes are way to thick... but like you said it might be the rotor also. is it only on one side or both of the sides?
Old Apr 6, 2014 | 12:28 PM
NCTL05's Avatar
It was on one side. Like you said I think that the new pads were too thick. I put the stock ones back on and the new rotor slid on like butter. I just need to adjust the parking brake now.
I guess if anyone is wondering what the best brand is for a parking brake shoe, I would say buy them from honda. Those Wearever shoes do not fit.
Old Apr 6, 2014 | 05:43 PM
Turbonut's Avatar
Here are a couple of replies about the Wearever shoes for the TL taken from the Advance Auto site:
(1)These park brake shoes don't fit the vehicle.Too large,excessive lining,linings too long,not arced.Vendor says there the only ones for this vehicle.You only have one other review and they said the same thing.I'm a 37 year ASE master technician with brakes certification in automotive and heavy duty trucks as well as a slew of others.I think I know what I'm talking about.It's late Saturday,the car is apart and I'm screwed. I even called the mfg's 800 number and they won't answer well before their closing time,(4:00 PM EST).You can bet I'll let a lot of people know.
(2)It is bigger than original pads
Old Apr 6, 2014 | 07:42 PM
nfnsquared's Avatar
OP: It's been documented in this forum that using other than OEM pads may cause this issue. You're not the only one that found this out the hard way.
Edit: MODS: Can you add a note to the first page of the DIY about this issue?
Something like "Note: Use of non-OEM pads has in some cases resulted in not being able to replace the rotor back on the hub due to the pads being too thick."
Old Apr 6, 2014 | 10:00 PM
NCTL05's Avatar
I will let them know my issue when I take them back. What is funny is that both the new rotor and brake shoes are the same brand. And still didn't work with each other.
Old Apr 11, 2014 | 11:18 AM
flyromeo3's Avatar
I need to replace my shoes also. Is it a difficult task to accomplish?
reading the service manual is intimidating me.
Old Jun 24, 2014 | 12:44 PM
Titanium2k2's Avatar
I'm at this same point right now. I too was intimidated by what's involved with the replacement. I'm going to set a side a Saturday this week or next and knock it out though.
Old Dec 21, 2018 | 07:59 AM
thegrinch911's Avatar
Auto Zone parts same as the Advance Auto. New parking brake shoes and the rotors will not fit. So they have not updated the specs on the parts so that they are compatible. I wonder if they are just not processing all the parking brake shoe returns and fixing the issue.
Old Dec 21, 2018 | 09:07 PM
Metalzone's Avatar
I bought some from Oreillys that also didn't fit. What I ended up doing was just replacing one out of the two that go into the drum assembly.
Old Dec 22, 2018 | 08:41 AM
Went and bought Acura replacements and it all fit right together with no issues. Auto Zone parking brake shoes are going back!
How do these aftermarket parts companies claim their parts are direct replacements if they do not fit?
Old Dec 23, 2018 | 08:15 PM
twokexlv6coupe's Avatar
I'll throw my .02c in.
Replaced my rear brakes 6 months ago with OEM parking brake shoes but CarQuest rotors.
It was a very, very, VERY tight fit getting them on. Needed a bit of, uhh.... persuasion from a 5lb mini sledge. But I'm pretty sure the rotors had a slight inner lip on them cuz once the rotors were fully seated on the hub they spun almost noise and resistance free- it was the lip rubbing on the shoes meat while getting them seated. So I decided to run with them, the meat would get worn down after some mileage.
Anyways, fast forward 6 months/3K miles later still running them ALMOST problem-free.
The only problem is when the car sits overnight in temps less than 20*F, the rotors must contract JUST enough and they literally freeze to the shoes! Takes a bit of rocking back and forth to finally break them free, then some slowww driving to slowly heat/expand the rotors up then i'm good to go.
It's not ideal, but at the time it was more ideal than my only other driveable car (2000 TL) had a rusted thru brake line, leaking fluid whenever I pressed the pedal.
Old May 23, 2020 | 12:06 AM
1woodreaux's Avatar
I know this is an older thread, but one that I wish I saw earlier as my parking brake pads essentially fell apart when I went to replace my rear brake rotors. So I had to replace them as an after-thought mid-process. I went to Pep Boys and picked up a set of Wagner Z782 parking brake pads for about $25. What could be the difference, right?
A couple hours, I learned the lesson(s) the hard way - and I usually buy all OEM!
As Turbonut and nfnsquared stated earlier in 2014, the aftermarket's are just slightly too big. After loosening up the emergency brake to its limit, I can squeeze the new rotors on, but they won't turn; they're just too tight. And I'm not going to burn up new pads and rotors to break them in by force driving them.
** Fast-forward one week ** I finally got my Acura / Honda pads, and they went in perfectly with no problem.
Summary: If you're seeing this thread trying to figure out the parking brake pad situation, BUY THE OEM ACURA/HONDA PADS! They are more expensive, but they work and will save you time from having to redo them anyway!
As a note, for the 2002-2008 TL's (to my understanding), the parking brake pads are the same as the Honda 2003-2011 Element and 2002-2004 CRV (Honda Part No.: 43154-S47-N01) and I found them cheaper from a local Honda dealer than Acura (a real shocker, I know).
To elaborate further:
1) My parking brakes were shot at 135,000 miles for a 2007 TL-S...
2) Yes, I occasionally use the parking brake to slow the vehicle down at speed to keep the brake lights from turning on. There are some things I don't want to 'advertise' around certain authority vehicle(s) when at velocities above posted limits...
3) Based on AcuraZine member feedback, I replaced the rear brakes with:
- StopTech Slotted Cryo Rotors
- Akebono Ceramic Brake Pads
- [now] Honda Parking Brake Pads
Old May 23, 2020 | 07:17 AM
DMZ's Avatar
DMZ
Head a da Family
When it comes to parking brake shoes, the OEM's from Acura are the only way to go as all the aftermarkets seem to have the same fit problem.
Old Aug 7, 2020 | 05:22 PM
VI Massive's Avatar
I did this job over the weekend, and although I'm not promoting Non-OEM parts, I did have luck with non OEM shoes. If I knew, I def would have gone with OEM Shoes. The job is intimidating with all those springs and clips in there, but it can be done. Hope this helps someone in the future.
Old Feb 10, 2021 | 12:07 AM
DesertMistTL's Avatar
https://youtu.be/R-x8k38RHzE
i just finished watching your video! do you like the raybesto hardware kit? I see centric is there as well. I might grab that and new oem shoes.
jkim4296
Aug 6, 2019 10:08 AM
Jovinki
May 22, 2016 12:32 PM
paperboy42190
Nov 21, 2013 08:26 AM
DanV's06TL
Jun 13, 2011 11:04 PM
sky2002
Jan 24, 2009 07:37 AM
