Big problem help
Old Nov 25, 2014 | 11:57 AM
Mcfrank69's Avatar
Big problem help
First of all im bad in nglish so
Thats happening last day
I put my key in the ketch Going to start the car but PAff. Nothing
And my car look like if my batt was dead but i swicthed à couple Time the key and the voltage Côme Back again réaly slowly and bang my car start
Any idea
maybe battery is dead.
Old Nov 25, 2014 | 01:20 PM
pohljm's Avatar
Sounds like a bad battery
Old Nov 25, 2014 | 01:51 PM
Mcfrank69's Avatar
its not the batterie (i think) because my car start all time ,don't sound like he forced to crank the engin .......look like if the signal doenst gom ..
and some time
i need to stay the key at start wait 10 second before he crank
Old Nov 25, 2014 | 02:45 PM
aIRpeACE's Avatar
it's a dying battery
Old Nov 25, 2014 | 02:47 PM
Will Y.'s Avatar
Registered but harmless
Possibly a bad battery cable connection-- check the cable clamps on the battery and connections on the other side (starter and ground).
Also can be a bad starter-- hit the starter with a metal bar or hammer while cranking. If the starter then starts, it's a bad starter.
Old Nov 25, 2014 | 03:38 PM
Jesstzn's Avatar
Or corroded connection, take then off and clean both the clamp and the posts .
Old Nov 25, 2014 | 04:55 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Agree with others in this post. It's likely either the battery or the starter.
Make sure connections to the battery are clean (free of corrosion) and tight (no movement).
Check the same for the other end of the battery cables.
How old is the battery??
Dashboard lights up completely and normally??
Follow what Will Y mentioned above regarding the starter.
Old Nov 26, 2014 | 08:03 AM
Mcfrank69's Avatar
I buyed the car with the batt
Good i will looked and give you more détail
Old Nov 26, 2014 | 08:29 AM
Mcfrank69's Avatar
Your right got damn
Its my fucking positive was free on thé bat
Old Nov 26, 2014 | 10:22 AM
Will Y.'s Avatar
Glad you solved the problem.
Welcome to AZ.
Old Nov 26, 2014 | 01:11 PM
NBP04TL4ME's Avatar
^+1 Welcome to Acurazine
cycdaniel
Dec 17, 2019 10:58 AM
Aug 15, 2019 12:58 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Junior Noboa
Sep 21, 2015 06:28 PM
brandnewcolony
Sep 12, 2015 10:39 AM
