Best touch up paint solution
Old Feb 8, 2012 | 09:08 AM
SilverJ's Avatar
Hi guys. I have a Silver TL-S with some minor scratches on the door and a couple on the rear bumper. I did a search and read thru some threads--it seems to me that the simplest/cheapest way was to get the touch up paint from the dealer (along with clear coat). Is this still the best way ? Is there a better option besides getting the paint from the dealer ? (I read this in the TSX section from 2005--hence me asking if theres something better now)
I know some guys would get their whole door painted but its not worth it to me as little chips happen way too frequently for that to be cost effective.
Old Feb 12, 2012 | 05:19 PM
Jase13's Avatar
I paint for a living and your best option is to go to a body shop and ask for a bottle of unreduced touch -up for your car. Most shops will give it to you free, I do. Good luck.
Old Feb 12, 2012 | 06:19 PM
DuoDSG's Avatar
Make it so
Thumbs up
The one I use (thanks to my frequent road trips) is:
http://www.paintscratch.com/
Go in there, input your paint codes, and you'll have a choice of how much of the paint you want and everything else you'll need. Much better than buying from the stealership, IMO.
Old Feb 12, 2012 | 07:04 PM
vietxquangstah's Avatar
I don't know if this is your exact same color code, but I just purchased this for my moms 2007 Alabaster Silver Metallic V6 Honda Accord SE
http://www.ebay.com/itm/Genuine-Hond...8#ht_500wt_922
I also have one in Nighthawk Black Pearl for my 08 TL. It's a all-in-1 pen, no need for clear coat. Well I always use just the pen to touch up the paint on my car, and never apply any clearcoat afterwards.
Old Feb 13, 2012 | 08:39 PM
Berat's Avatar
You can purchase touch up paint from the dealer. This is for a 08 NBP http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Feb 28, 2012 | 10:19 AM
SoftwareDrone's Avatar
If you have small rock chips, try the Langka kit. If you have "rash", try the DrColorChip kit. For larger rock chips, fill in with factory touchup paint, then coats of clear coat until it dries higher than the surrounding surface, then carefully 2000# down and polish with Maguires Swirl Mark Remover.
Actually, only do the color sanding if you have prior experience.
Old Feb 29, 2012 | 06:33 PM
Jase13's Avatar
This will not work with metallic. If it were a solid color you could add some clear to unreduced base and touch-up then sand smooth. Again, just go to a body shop and ask for some unreduced base.
Old Mar 1, 2012 | 08:47 AM
Seems to work for me...
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
polish_pat
Sep 30, 2015 12:22 PM
jmaxima03
Sep 27, 2015 10:22 AM
