Is it the battery or the wiring or both
Old Aug 5, 2015 | 03:59 PM
CoCo784's Avatar
3rd Gear
I have an Acura TL 2004 and lastnight it wouldn't start tried to get a jump lights came on but it wouldn't turn over heard the clicks but before he could even hook it to his battery my lights came on so o was confused that once it was hooked to his car that it wouldn't turn over. Not sure what to buy first but those wires being exposed I know I have to do that I just pray it's nothing major any ideas.
Old Aug 5, 2015 | 10:10 PM
polish_pat's Avatar
Def wiring. Not enough of those wires are making contacts with the terminal so not enough current is flowing to starter, thus hearing that clicking noise. This wear seems to be some king of force because if it were anything else, those wires would be corroded/rusted/oxydized, which they are not and look perfect to me.
Old Aug 5, 2015 | 10:44 PM
Will Y.'s Avatar
Registered but harmless
That looks like a replacement non-OEM battery clamp, so the original was probably replaced for corrosion. I'd feel along the positive battery cable to see if the corrosion (the white powdery spots in the cable strands) is further within the cable; if so, the cable will need to be replaced.
Also check the negative clamp for tightness-- it's been known to get loose frequently.
Finally, how old is the battery? If the answer is 3 years or more, I'd start with a new battery-- a completely dead battery is difficult to jump.
Welcome to AZ.
Old Aug 6, 2015 | 03:03 PM
CoCo784's Avatar
3rd Gear
We'll I'm going to try to get things done today I will reply later today or tomorrow with the end result but u think you for all the ideas you really help me narrow down the problem
Old Aug 6, 2015 | 03:04 PM
CoCo784's Avatar
3rd Gear
And the battery is a year old
Old Aug 9, 2015 | 12:00 AM
CenturionTL's Avatar
Its your starter cable (battery wiring). You need to replace the entire cable.
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
