Battery drain 2005 TL - Fuse 7
Old Nov 11, 2019 | 01:04 PM
6for2's Avatar
Recently I have been experiencing a battery drain on my TL. I checked the underhood fuse box and found that fuse 15/Back Up/ACC had a draw on it. I narrowed it down to the interior fuse 7, which reads as this in the shop manual:
Fuse 7 - 7.5A WHT/RED
Audio-HVAC display module, Clock (without navigation), Combination switch control unit, Gauge control module, Front passenger's power window switch/control unit, Immobilizer control unit receiver, Navigation unit, Security indicator, Power window master switch, Power mirror control unit XM receiver unit
Fuse/relay Multiplex integrated control unit (MICU)
Not sure of the best way to move forward from here. It probably isn't the MICU if the drain is only on fuse 7, or could that still be a possibility? Thanks.
Old Nov 11, 2019 | 01:11 PM
peter6's Avatar
It tells you what is feed by that fuse, so simply start unplugging stuff to narrow down ever further. I would start with clock, then XM receiver, then power window switch (pass and driver).
Old Nov 11, 2019 | 01:38 PM
Will Y.'s Avatar
Registered but harmless
Disconnect the HFL/Bluetooth unit first, then check the draw.
The largest ignition-off electrical drains are a defective HFL (measured when the car has been turned off for an hour, as the HFL is designed to stay live for a half hour after ignition-off), then a bad AC relay.
Old Nov 11, 2019 | 01:40 PM
6for2's Avatar
Thanks. The HFL has been disconnected. The A/C relay didn't have an impact on the draw when I pulled it.
Old Nov 11, 2019 | 01:41 PM
6for2's Avatar
Thanks. I didn't know if there was a particular item in the list that was commonly troublesome.
Old Nov 14, 2019 | 08:22 AM
Turbonut's Avatar
Mine was the pw master switch, can't remember the draw, but drained the battery in a couple days.
Takes time to isolate the culprit.
Old Nov 14, 2019 | 08:23 AM
6for2's Avatar
Thanks. Sold the car before I was able to pin down the cause, but gave the new owner a heads-up on where to look.
Old Sep 18, 2021 | 12:57 PM
mraurora's Avatar
If my power windows are working, I can rule out the pw master switch as the culprit for my parasitic drain, correct? Or can things be functioning properly (seemingly) and still be the cause of the drain?
Turbonut
Sep 24, 2018 05:10 PM
NCTL05
Mar 5, 2014 09:42 PM
Oakroadsteve
May 8, 2012 06:02 PM
tl206
May 30, 2011 09:13 PM
Tyson0110
Nov 4, 2010 08:25 AM
