Air won't stop blowing
Old 05-19-2018, 12:45 PM
4th Gear
Bakka's Avatar
My air constantly blows . Dont know how to fix it
Old 05-19-2018, 02:14 PM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Any particular kind of car?
Please reply. @Bakka
Old 05-22-2018, 11:20 PM
4th Gear
Bakka's Avatar
05 Acura tl
Old 05-22-2018, 11:22 PM
4th Gear
Bakka's Avatar
I hit the off button the air still blows . No matter what I do the air wont a tip blowing. I
Old 05-22-2018, 11:59 PM
GhostTL09's Avatar
use the hands free and see if the verbal command will turn off the blower
Old 05-23-2018, 02:00 AM
Received 8,584 Likes on 6,630 Posts
Does the fan in the engine also run
Old 05-23-2018, 12:23 PM
4th Gear
Bakka's Avatar
No fans are on under the hood. When I turn the key to the on position the air blows .
Old 05-23-2018, 12:27 PM
Have you recently taken apart your center console for something? to install a radio perhaps?
Old 05-24-2018, 08:37 AM
Administrator
Ron A's Avatar
Welcome to the forums.
Since this is a topic/technical issue which will require replies, and not a "New Member Introduction", this thread has been moved to the model specific forum.
Old 05-26-2018, 01:32 AM
4th Gear
Brian Camilo's Avatar
When you turn the key to the accessory position (II) or start the car, the blower motor fan blows the air to the max? This happened to me two days ago and it wouldn't turn off even if I pressed the OFF button. I removed the glove box and took out the Blower motor resistor and it doesn't blow anymore. Makes me believe that my resistor went out. I already ordered one, will let you know if that was the problem.
Old 06-01-2018, 02:22 AM
4th Gear
Replacing the resistor solved the problem for me, so you might want to look into that if you have the same symptoms.
Old 06-11-2018, 09:44 AM
kevintl21's Avatar
Will the blower motor resistor not make the compressor turn on? Cause my TL stopped blowing cold air and the fans went to high and when hitting the off button blower motor stays at high and no cold air... Please advise Acura Master Techs. I did the self diagnosis for the A/C and showing fault for blower motor..
Old 06-11-2018, 09:52 AM
losiglow's Avatar
Is it just lightly blowing or is the fan actually making noise and cranking out a significant amount of air? If the recirculate is off, you'll have some air constantly coming from the vents - more as your speed increases or if you have the sunroof or windows open. If that bothers you, turn on the recirculate then turn off the air and it will stop.
I'm assuming that you have the fan cranking out a lot of air but figured I'd mention it just in case.
Old 06-19-2018, 03:23 PM
kevintl21's Avatar
So it was the blower motor resistor that was shorted causing the blower to blow on high and causing the A/C not to work.. it threw me off cause I i didn't know a blower motor resistor would not engage the compressor..
Old 09-25-2020, 08:35 PM
7th Gear
kdubsup's Avatar
i did this (installed an aftermarket stereo) and I’m having the same issue. My climate control is illuminated, but no digital controls. And my air is full blast on defrost. Switching from hot to cold.
Old 09-20-2021, 06:50 PM
100x600day's Avatar
this same exact thing happened to me as well’ Did you figure out the problem ?
bpadichith
07-03-2020 08:42 PM
3darray
09-11-2015 12:28 AM
Fyn3r808
08-22-2014 09:58 AM
killerjonan
1G TSX Problems & Fixes
09-28-2010 11:56 PM
sistom
09-15-2005 06:56 PM
Quick Reply: Air won't stop blowing
