Battery Died?!
Old Jun 23, 2008 | 10:47 PM
ricgrrarrow's Avatar
Stuck in Vegas.
Battery Died?!
today had my tl's battery die, TWICE! once after work, and once at my house.. brought it to autozone to recharge it, it turns out to be a bad battery. gotta 100mnth warranty thru acura. i had to buy a battery, my car was stuck windows down and all.. sooooooooo here's the question
is acura gonna reimburse me for me having to drop a hundred bucks on a batter? it's still under warranty, right?
ugh this has pissed me off soooo bad!! should i bring it into acura and try for a reimbursement? or not bother trying?
Old Jun 23, 2008 | 10:49 PM
ILLustriousUA6's Avatar
Feenin on some 20's
^ i just got my battery replaced for free under warranty. It was a bad battery. go to the dealer and give it a shot
Old Jun 23, 2008 | 11:02 PM
erick3's Avatar
dude, SCREW the acura batteries. I had mine replaced under warranty and then a few months down, IT DIED AGAIN. Ended up going to an Optima Yellow Top; starts up strong every time. As for the reimbursement, I'd go AGAINST. The stealerships are ALL *itches with it comes to "manufacturers" warranty. The fact that you decided to go with another brand battery, instead of their Acura brand battery in itself will give them means to give you a hard time. BUT HEY, it wouldn't hurt to try...
erick3's Avatar
how many miles btw?
Old Jun 24, 2008 | 12:03 AM
01tl4tl's Avatar
in this case its beyond the dealers abilty to do anything directly for you on warranty.
normally if you had been able to get it to the dealers shop...
Since it was an emergency- send a copy of the receipt to acura corp in LA
asking for reimbursement
Explain you were stuck and otherwise love your acura- would have been happy to go to the dealer had it been possible....
they can write a check for anything they really want to !
Old Jun 24, 2008 | 12:33 AM
Stuck in Vegas.
Originally Posted by erick3
how many miles btw?
this is my 3rd battery replacement!!!
i have 48k , but only 10k on this battery. the stealership blamed the vegas heat, but i doubt it this time.
Stuck in Vegas.
where do i get corporate's info?
Old Jun 24, 2008 | 04:31 AM
01tl4tl's Avatar
its in the owner book- or call and ask 1-800-382-2238x5
Old Jun 24, 2008 | 04:34 AM
01tl4tl's Avatar
do you have bigger stereo or other type equipment on the car?
acura has a cheap little battery- and 2 years in vegas is like 4 years anywhere else,,,
but 3 batteries- is there a bad ground wire issue or alternator overcharging issue??
Azone or whoever- will test the system for free to make sure the new battery is going to be the only solution- may be another problem killing the battery
Old Jun 24, 2008 | 09:58 AM
JDM5lugHatch's Avatar
Now with i-Vtec
There was a recall on the early 3 gen TL's. Something to do with the nav unit drawing too much current so they had to put a clamp on it. I got the recall but never took the car in for the fix because I had the Nav to DVD converter. I didn't want to hear them bitch about it.
Here is a thread I found concerning it.... https://acurazine.com/forums/showthr...all+navigation
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
mars
Sep 28, 2015 11:03 AM
