Battery being drained
Old Oct 15, 2012 | 03:59 PM
Manimal_Forever's Avatar
Hey folks, the battery in the car keeps getting drained super fast, as in 2 nights and the battery will be dead. Any known reason I should check? swapped batteries twice already and still the same thing happens.
Old Oct 15, 2012 | 07:07 PM
Hi speed's Avatar
runnin a little boost
Yup, HFL is bad and draining the battery. Google HFL battery drain. Try to use the HFL ( hands free link ) or Bluetooth and see if it works. The HFL battery drain is a very common issue. It can be disconnected and left where it is if you don't use it. It will kill your ability to use nav voice commands, with it disconnected.
Old Oct 15, 2012 | 08:23 PM
Thanks man let me try that and see what happens!
Old Oct 23, 2012 | 09:35 PM
SolarScout's Avatar
6th Gear
I had a similar issue twice when I left town for a week each time. Did pulling the HFL fuse work?
Old Oct 24, 2012 | 07:38 AM
omnuts's Avatar
2006 TL: WDP/Ebony
^ You have to disconnect the HFL module for this to work, not the fuse.
Old Oct 25, 2012 | 03:04 PM
08WDPTL's Avatar
I thought there was a TSB for this (battery draining excessively) a long time ago?
Old Feb 9, 2018 | 05:22 PM
jimmriley's Avatar
Jmr
acura service bulletin 05-020 addresses the problem with the HFL/Bluetooth unit draining the battery
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
