Bank 1 and 2 lean, loss of power
Old Aug 9, 2020 | 06:40 PM
kobydc9's Avatar
9th Gear
Exclamation Bank 1 and 2 lean, loss of power
I don't know if this topic has been covered before but, recently car's cel came on with codes p0171 and p0174. All 4 of my o2 sensors were changed within the last month. Also my car run rough on startup for about 10-30 seconds depending on how cold it is but then idles back up at about 1k rpm. The tp is reading at 14% at idle so the app sensor was also changed but still read 14%. The car loses all power if I give it more than 60% throttle and will almost never exceed 60mph. Any advice or help would be appreciated.
Old Aug 9, 2020 | 07:11 PM
what brand o2 sensors?
Old Aug 9, 2020 | 07:14 PM
kobydc9's Avatar
9th Gear
Denso
Old Aug 9, 2020 | 07:24 PM
peter6's Avatar
Lean codes and no power? Check fuel pressure.
Old Aug 9, 2020 | 08:18 PM
kobydc9's Avatar
9th Gear
the shop checked and said I had normal fuel pressure
Old Aug 9, 2020 | 10:32 PM
peter6's Avatar
If you're going through the shop let them come up with solution and fix your car.
If you want to fix the car yourself, do all the checks yourself.
I would check fuel pressure while engine is under load. Idling or simply commanding fuel pump ON with scan tool is often not enough.
Old Aug 10, 2020 | 08:06 AM
Ted Kief's Avatar
Dirty injectors and vacuum leaks will give you lean codes.
uvb4less
Jul 31, 2025 02:56 PM
KrAzYForever
Apr 21, 2014 12:41 AM
MAREL27
2G CL Problems & Fixes
May 28, 2011 12:03 PM
rhino-31
Dec 20, 2010 06:14 PM
euroStyle
Jul 30, 2008 06:38 PM
