Ball Joint Sleeve Removal
Old Mar 18, 2013 | 09:05 AM
BrianC636's Avatar
I put new bushings in the lower control arms and put the TL-S swaybar on the wife's 04 TL this weekend which was mostly painless. However in the process, I noticed the boot for the lower ball joint was cracked on one side.
I've got a pitman arm puller and a nice 2 jaw puller however I can't seem to get the sleeve off the ball joint that goes into the control arm to replace the boot.
Any other suggestions? I planned on running by HF and getting their little $20 ball joint separator to try also.
Old Mar 19, 2013 | 08:23 AM
johnny3's Avatar
That bushing bushing should have stayed in the arm bur sometimes it does'nt. Soak it real good a few times with penetrating oil & peck around on it with a plastic hammer while prying upward with a screwdriver, be careful & don't ding it up beyond repair cause I'm not sure you can buy it seperatly. Warm it up a little with a propane torch & soak while it's expanded, it will finally turn loose.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
lowgrowl
Sep 26, 2015 05:18 PM
Brandle34
Sep 23, 2015 07:20 PM
0opie
Sep 22, 2015 04:15 PM
