Bad ECU?
Old Mar 8, 2011 | 11:52 PM
tl_dinhsum84's Avatar
Bad ECU?
so one day my check engine came on at 99k on my 05 and i took it to autozone and they said i have a bad ecu?? are ecu's usually suppose to go out at 99k? lately something had been wrong with my power i would get to the car and wont start. but when i tap the batteries with something metal it would come back on?
i also have some corrosion on the negative of the batteries would this cause the problem? but what about my ecu? i need help fast because this is becoming more of a problem like losing my power and constantly hitting my batteries to come back on!
Old Mar 9, 2011 | 12:45 AM
any help?
Old Mar 9, 2011 | 02:09 AM
Marmbo's Avatar
If there is something wrong with your ECU, hitting the battery should not fix it or make any difference. I'd remove both battery terminals and clean them up as a bad connection can cause problems. If the ECU has failed no hitting of the battery should get it going again.
Old Mar 9, 2011 | 09:00 AM
thanks marmbo. thats what i needed im going to try that today lets see what happens
Old Mar 9, 2011 | 09:04 AM
umm have you cleaned the terminals yet?
what was the EXACT code that autozone pulled?
ALWAYS ALWAYS get the exact code when checking, because "ECU going bad" is to broad and general.
I'm betting its the APP sensor. GET THE EXACT CODE
Old Mar 9, 2011 | 09:05 AM
not yet i will try that today
Old Mar 9, 2011 | 09:07 AM
when i went to autozone, it said ecu or ecm malfunction
Old Mar 9, 2011 | 09:10 AM
^thats not the exact code.
it will give a code, and a description...
but with your description of hitting the battery, tells me that the connections are loose or corroded.
Clean them. and see if your problem persists.
Old Mar 9, 2011 | 09:45 AM
stvtec's Avatar
'06 WDP TL 6MT
Definitely a bad battery connection. Maybe your battery is even going bad. But I would not be concerned about the ECU whatsoever.
Old Mar 9, 2011 | 06:33 PM
u guys were right it was a the corrsion, but i wonder why the ecu malfuction showed up when i went to check the check engine light. .
Old Mar 9, 2011 | 07:25 PM
because....you didnt have a good connection to the battery.
causing all sorts of ELECTRICAL mishaps to happen.
Old Mar 10, 2011 | 12:21 AM
thanks lesson learnedthis would costed me 620 for just the ecu part
TypeS860
Jan 10, 2026 11:11 AM
Timmy18
Oct 17, 2015 03:58 PM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
hrothgar02
Sep 28, 2015 11:08 AM
