Automatic windows doesnt work after battery died!
Well i was sitting in the car with the battery on for about half hour and the battery died. after my friend gave me a jump everything was back to normal but the AUTOMATIC up/down windows doesnt work. (it works if i hold the up/down button) any suggestions on how to fix it?
Drive it like its Stolen
Get your owners manual out.....it tells ya how to reset them.
press the window button all the way down till the window is completely open. hold it for a couple seconds. then roll it all the way up and hold it for a couple seconds. Cant remember if you need to do this from the passengers side or if the drivers side control will work.
Page 22-224 It is a pretty lengthy process.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
1. Turn Ign switch on
2. Move the driver's(passenger's) window all the way down by using the driver's(passenger's)window DOWN switch.
3. Open the driver's(passenger's) door.
NOTE: Steps 4-7 MUST be done within 5 seconds of each other.
4. Turn the ingnition switch OFF.
5. Push and hold the driver's(passenger's) window DOWN switch.
6. Turn the ignition switch ON.
7. Release the driver's(passenger's) window DOWN switch.
8. Repeat steps 4-7 three more times
9. Wait one second.
10. Confirm that AUTO UP and AUTO DOWN do NOT work. If AUTO UP and DOWN work, go back to step 1.
11. Move the driver's(passenger's) window all the way down by using the driver's(passenger's) window DOWN switch.
12. Pull up and hold the driver's(passenger's) window UP switch until the window reaches the fully closed position, then continue to hold the switch for 1 second.
13. Confirm that the power window control unit is reset by using the driver's(passenger's) window AUTO UP and AUTO DOWN function.
If the window still does not work in AUTO, repeat the procedure several times, paying close attention to the 5 second time limit between steps. If it still does not work, go to B-Can System Diagnosis Test Mode A(see page 22-108)
Your welcome.
9. Wait one second.
Your welcome.
bonnhew (12-16-2011)
TLDude876
12-28-2016 03:18 PM
ahsm
09-09-2015 08:35 AM
