auto window not working. HELP!!
Old Apr 22, 2006 | 02:43 PM
robs04TL's Avatar
2 FAST TL
Hey guys, I just got into my car and went to put the driver side window down and when I pressed it to automatically go down it wasnt working but the passanger side will.. Any advise on what the heck happened??
Old Apr 22, 2006 | 10:18 PM
Ron A's Avatar
Administrator
Will it go down if you just press the switch lightly, but not when you press the auto button? If so, it migjt be a faulty switch.
If it doesn't work at all, you could check Fuse #27 in the fuse box next to your left leg (when you are sitting in the car).
Old Apr 23, 2006 | 03:14 AM
aznbo187's Avatar
Did you happen to unplug the battery by any chance?
Old Apr 23, 2006 | 09:56 AM
robs04TL's Avatar
2 FAST TL
Well, the window goes up and down when i hold it and this all started after i picked up my car from Midas..Maybe they unplugged the battery? Any ideas on what i can do?
Old Apr 23, 2006 | 10:52 AM
Ron A's Avatar
Administrator
Page 99 in the 2004 owner's manual (nearby for later models):
If your vehice's battery is disconnected or goes dead, or a front window fuse is removed, the AUTO function could be disabled. If the AUTO function is disabled, do the following:
1. Start the engine. Push down on the front window switch until the window is fully open.
2. Pull back on the front window switch to close the window completely, then hold the switch for a second or two more.
If the power windows do not operate properly after resetting, have your vehicle checked by an Acura dealer.
Old Apr 23, 2006 | 11:06 AM
robs04TL's Avatar
2 FAST TL
Hey, I did what you said Ron and it worked!! Thanks for the help. I appreciate it
Old Apr 23, 2006 | 06:20 PM
Adobeman's Avatar
The DVD-A Script Guy
Originally Posted by robs04TL
...this all started after i picked up my car from Midas...
Eeeeek ! Midas working on a 3GTL ? I dunno, something just feels wrong about that.
Anyway it's great news that you caught that fix from Ron. I guess I was lucky mine didn't do that after I disconnected my battery recently. I never would have figured it needed to be reset in a million years.
Old Apr 24, 2006 | 08:49 AM
robs04TL's Avatar
2 FAST TL
Well, The only reason why I went there was because my buddy works there and I got it done for free...Otherwise the dealer does everthing.
Old May 19, 2006 | 09:45 PM
05TLTony's Avatar
Dr. Feelgood
Thank god I found this thread! The exact same thing happened to me today. I knew AZ was good for something.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
