Auto Window down stopped working
Old Feb 7, 2009 | 04:15 PM
njfinest05's Avatar
So today I put type s taillights on my car and i love the outcome, except for the right side of the bumper not being 100% flush for some reason. While doing the swap I had the car off but the radio on and the battery died. And now I notice the auto window up/down feature isnt working on the driver side but it does work on the pass. side. and since I cant figure it out i figured id come to az for the help
Old Feb 8, 2009 | 06:56 AM
njfinest05's Avatar
any ideas???
Old Feb 8, 2009 | 11:51 AM
Will Y.'s Avatar
Registered but harmless
Hold the window switch until the window is all the way down, then pull the switch to bring the window all the way up again to reset it. The procedure is also in the owner's manual, but hopefully that'll cure your problem.
Old Feb 8, 2009 | 11:53 AM
PeterUbers's Avatar
you need to reset the window:
Turn car on
roll the window down all the way and keep pressing the down window button (do this from the driver's side control) and keep holding it for about 10 seconds after the windows rolls all the way down.
then...
pull up on the window up button and keep holding it even after it completely closes... keep holding it for about 10 seconds.
Now your window should be reset... try the auto up/down...
Old Feb 9, 2009 | 05:59 AM
njfinest05's Avatar
So I tried the window reset and it didn't work. So I pulled the fuse out and put it back in and voila...window works perfect. Im guessing it was just a bad connection??
Old Jul 5, 2010 | 02:20 PM
vadimka's Avatar
6th Gear
Hey i got exactly the same problem
Which fuse i got to check. Thanks.
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
ahsm
Sep 9, 2015 08:35 AM
dlknight
Sep 3, 2015 07:54 PM
