Anyone replace their wiper linkage?
Old Feb 3, 2014 | 06:27 PM
Scottwax's Avatar
Mr. Detail
My wipers have excessive travel, hitting the A pillar on the driver's side and both clunk when they hit the black plastic under the windshield. It isn't consistent (sometimes travel is normal) but it seems to be worse at freeway speeds. It isn't the nut that holds the wiper arms on, both are tight. But there is a good inch of play if you try to move the wiper arms.
Just wondering if anyone has replaced their linkage and can give me an estimate on difficulty and time. Used to turn wrenches on my domestics all the time, less so on the imports I've owned but I'm pretty good mechanically.
Old Feb 4, 2014 | 02:46 PM
gyang401's Avatar
same thing is happening to mines....i work at honda, talked to one of my buddy which is a certified technicians, he said he changed out 2006 accord wiper linkages cause it had the same problem as mines, and it was fairly easy, just have to pop the linkages out with a good size flat head screw driver, n pop in new ones, and advise to change out both, due to the nylon bushings being worn out!
Old Feb 4, 2014 | 03:35 PM
Scottwax's Avatar
Mr. Detail
Cool, thanks. Probably should also get the plastic fasteners that hold down the plastic covering, usually end up breaking some whenever I remove them.
Old Feb 4, 2014 | 03:37 PM
gyang401's Avatar
heres what i found, n is pretty much exact how my buddy mentioned
https://acurazine.com/forums/showthread.php?p=10325381
csmeance
Jan 7, 2026 06:25 PM
TL-Rocket
Apr 29, 2023 02:33 AM
niray9
Dec 8, 2015 07:34 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
02tljj
Sep 11, 2015 12:37 PM
