anyone experience hard shift on auto?
Old Apr 29, 2008 | 06:26 PM
RTLNOOBIE's Avatar
i have 04 tl about 52k on it and it probably does it before but i didn't notice. when i shift from Park to revers i can hear my trany shift hard. same as from drive to park it make a hard click sound when it past the reverse.
does anyone have the same issue before? or it just normal?
Old Apr 29, 2008 | 06:45 PM
01tl4tl's Avatar
how long/seconds is the delay engaging into Drive after you shift- does it take a few seconds before its really enagaged and ready to move
Does it do it warm too- on cold start there may be some noise
Are the motor mounts ok- a broken mount will make clunk
It could be a transmission failure symptom too
I would look at the mounts- then get to the dealer for inspection
Being just over warranty they should hook you up- if its trans-
gen2 has a bad prob with them and got a court ordered 109k miles warranty- the prob continues in 04 05 models
Old Apr 29, 2008 | 07:46 PM
csmeance's Avatar
noise is normal, it is the transmission disnganging and engaging. The only thing that keeps your car in Park is a 1/2 inch of metal, and that has a lot of stress on it when it is put into place, when it disengages, it pops out due to the stress. Here is how to stop those noises:
Car in drive-> neutral->parking brake up all the way -> let of brake -> then back on brake -> put in park.
This way the weight of the car rests on the rear brakes and not the transmission. When going into drive, do this:
Car in Park -> to Car in Drive/reverse -> parking break down
Old Apr 29, 2008 | 07:59 PM
BLACKURA_NY's Avatar
I have car ADD
^ ive been using parking brakes on ALL my auto transimission cars, since day 1
it allowed my `92 ford explroer to have 270k+ on its tranny, without failing
Old Apr 29, 2008 | 08:31 PM
01tl4tl's Avatar
RTL
Not all noises are normal- to eliminate if its pressure on the parking gear
ON a level street with the park brake off and the car in park-
foot on regualr brakes- start car- wait 30 seconds- put in drive
listen
then move from n to d several times- with foot on brake
noting if the noise or time to engage or anything changes
Dismissing a trans noise without investigation is a recipe for failure
Old Apr 29, 2008 | 09:29 PM
sifuacura's Avatar
There's alot of asian in
i have that noise to, but when i step on the brake a lil harder than usual and than reverse..the sound is very low..thats for uphill parking. flat surface = no noise
Old Apr 30, 2008 | 12:41 AM
erick3's Avatar
normal...BELIEVE ME i've been back and forth from the dealership PLENTY OF TIMES and I confidently say that THAT, my friend, is NORMAL.
acura of lynnwood and acura of bellevue thought i was lol
Old Apr 30, 2008 | 12:44 AM
erick3's Avatar
OH, but I would recommend a COMPLETE transmission flush...really helped my tranny out; shifted back and forth better out of park, etc and helped it shift better
Old Apr 30, 2008 | 05:32 AM
RTLNOOBIE's Avatar
Thanks everyone!...i'll give it a try on all the advice you guy give me..thanks
did you bring it to the dealer or you do it yourself? i done a MT flush before but not on an AT.
Old Apr 30, 2008 | 05:39 AM
RTLNOOBIE's Avatar
no delay, it kicked in and hard on the reverse.
yes
i'll look around for that.
Old Apr 9, 2010 | 01:04 PM
gotkilled's Avatar
NBP is a pain...
I have the same issues. Brought it into the dealership and service advisor affirmed the issues. They said it was the transmission mount and it would be replaced under warranty.
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
kuzdu
Sep 10, 2015 08:42 PM
