Anyone else have this Prob w/ DeckLip Spoiler?
Hey guys just wondering if anyone had a similar problem that I am with the Rear Deck Lip Spoiler... I had it installed by my dealership and a week and a half later one side is popping up...any suggestions, Id take it back but the lip was bought on ebay and they where doing a favor installing it?
The only solution will be to remove it, remove all the 2 side tape. Get new tape from the local Autoparts store ( 3M makes it) and you want the one with the red peal-off, very sticky.
Get some wax remover at the same time and clean the surface at least 2 times as the stuff is quite volatile and will evaporate quickly. Do both the trunk surface were the lip will be installed and under the lip itself where the 2 way tape will be applied.
Apply the 2 way tape to the lip and then you can install it on your car.
Once installed, try to limit using your car for the next 24 hours which is the period it will take for the 2 way tape to reach maximum adhesion.
Best regards
frenchnew
Big Brother is Watching..
actually, the problem is with the adhesive, not neccesarily the install.
we have had a couple cars come back with the same problem. i myself am an accessorie tech at an acura dealer and have installed numerous spoilers, including the one on my TL. most likely if you take it back to the dealer, they will install a whole new spoiler rather than re-tape your existing one. thats actually how i got mine. i got one from a car that came back and had the one we took off sprayed to my color and i re-taped it.
quanaman
01-09-2023 07:33 PM
