Anybody can help me and know what this light is
AZ Community Team
Received 7,771 Likes
You can look those lights up in your Owners Manual.
If you do not have an Owners Manual, you can veiw it on-line if you register at MyAcura here: http://owners.acura.com/landing.aspx
Or look up your Owners Manual here: http://www.automanualonline.com/
AZ Community Team
http://www-odi.nhtsa.dot.gov/recalls/results.cfm
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Do you have a link or additional information?
Edit: maybe you mean this one? TSB 05-043: Safety Recall: Right Front Impact Sensor Is Loose ??
The only recall I have had on my 06 is the power steering hose.
One thing to note about the SRS fault is once it's set, it needs to be intentionally reset, meaning it won't do it itself. I had this happen when I removed a seat and had to turn the car on removed to test something.
Like MIL codes and the CEL.
Hmm I have the exact same issue right now, the only difference is that I had swapped out my interior to convert it black (courtesy of ack05tl, and loving it!). so i was considering to take it out to the dealer to get it fixed, but no warranty. so before i take such an expensive and drastic measure, is there anyone here that can help determine what the issue might be?
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
