AntiFreeze and Coolant
Old Nov 23, 2008 | 12:12 AM
OctoberFestFan's Avatar
I love Beer
Does anyone know if it is ok to use "Prestone All Makes/Models antifreeze coolant" in our 2004~2008 Acura TL?
The antifreeze we have comes blue. If we are doing a complete flush, do we have to use the blue ones by Honda/Acura dealership or we can use the GREEN color Prestone All Makes and Models?"
Old Nov 23, 2008 | 12:56 PM
Adobeman's Avatar
The DVD-A Script Guy
There's been debate. Some think you should stick with OE others say as long as you do a complete flush you are OK.
What's your mileage/ car age?
Read:
https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-coolant-558600/
Try "site:https://acurazine.com/ coolant antifreeze" in Google and that will get you plenty of hits.
Old Nov 23, 2008 | 05:28 PM
I hate cars's Avatar
Stick with OE. The stock Acura fluid has no silicates and the phosphorus and other elements has to be balanced. The number one problem when going with an aftermarket fluid is leaking water pumps. Just not worth it to save a couple bucks.
I'm a big believer in deviating from OEM fluids when you can. After lots of research I use non recommended Amsoil ATD in the trans and synthetic powersteering fluid which is also not recommended. But when I was looking at coolant I came up with two conclusions.
The stock stuff is great.
Anything else opens up the potential for leaks and metal corrosion.
Old Nov 23, 2008 | 05:59 PM
ssmtl2nv's Avatar
2009 g37s 6mt
oem for sure
Old Nov 23, 2008 | 06:23 PM
TL|GTX's Avatar
A Black TL
Amsoil, has really good engine oil, and powersteering oil, and transmission fluid. Idk if they have brake fluid?
Old Nov 23, 2008 | 06:30 PM
They came out with a brake fluid a few months ago. Personally, even though I'm a big Amsoil fan, I would use the cheapest DOT 5.1 I can find.
All DOT brake fluid is synthetic and always has been. Valvoline and others that market theirs as synthetic are just playing on the fact that most people don't know that all brake fluids are synthetic. This is the reason I would go with the cheapest fluid that met my specs.
Old Nov 30, 2008 | 10:56 PM
ezland00's Avatar
I notice that my antifreeze is below the min. line. i think it's due to CAI installation. My car has 40k miles should i flush the whole system or just add some antifreeze.
Old Dec 1, 2008 | 12:25 PM
ssmtl2nv's Avatar
2009 g37s 6mt
add fluid...
merc009
Jan 27, 2016 10:34 AM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
2Quik
Sep 21, 2015 08:51 AM
