annoying noise that I cannot locate
Hey 3G peeps -
First, I've used this forum for countless problems/ideas since I've had my TL since June 2019 so thanks for posting info and keep it going please.
Now, I have this annoying noise that is coming near from the passenger side of the engine that I cannot pinpoint. I took the drive belt off yesterday thinking i could test every pulley and surely one would be the culprit but they all seem to be operating as normal - no wiggling and all rotate without problems but unsure really how to know if it is a bearing going bad though. Any advice would be great.
The belt is newer, was replaced in June 2019 so I'm pretty sure that's good too, visual inspection didnt show any abnormalities. I think it may be coming from the a/c compressor but hopefully not.
*i have attached a video plus a couple pics of the TL. A map bulb burnt out the other week so i ordered some blue LED from amazon and they look cool but holy hell they are so bright it would be a major distraction to drive with at night or even be driving next to me with one on. thought i'd post anyways.*
I CANNOT UPLOAD THE VIDEO FOR SOME REASON, PLEASE SEE ON YOUTUBE link
Sounds like air in your power steering line.. If you pop the top off the reservoir, is it bubbling up? May need to rebuild your pump with all new o-rings/seals https://acurazine.com/forums/3g-tl-p...-scans-841134/
Also, this only occurs when it's been sitting overnight or very long periods of time. I'm far from an expert at this but would it not be making that noise all the time or why only intermittently and only cold start?
Problem found and fixed
I bought the tensioner pulley in hopes it was the problem and when I had the freaking timing belt, water pump required maintenance done today, my mechanic said the top pulley would spin continually do was definitely bad.
Thanks for the spot on replies to my original post.
justnspace (08-18-2020)
R1ck
03-09-2015 03:18 PM
nazTL
08-01-2013 09:46 PM
