All 6 cyclinders misfired....
Old Feb 3, 2012 | 08:09 AM
Damian0216's Avatar
Last night I started my car and all 6 misfired multiple times. I ended up with 14 codes and it all repeated 1-6 misfire and multiple misfire code. Any ideas???
I just did my sparkplugs sometime during fall of 2011 so I wouldn't think those would of gone bad already....
85k on the car 2008 tl type s
Old Feb 3, 2012 | 08:14 AM
auto or manny tranny?
Old Feb 3, 2012 | 08:32 AM
Damian0216's Avatar
Manual
EL_PIC's Avatar
Rich and Famous
I see your problem as more a computer mgt problem...
What are the specific codes ...
Old Feb 3, 2012 | 08:34 AM
Damian0216's Avatar
Old Feb 3, 2012 | 09:12 AM
Project_CLean's Avatar
MMkay.
any previous symptoms? should still be under warranty no?
those are all misfire codes; could be anything from fuel to ignition.. needs more diag.
Old Feb 3, 2012 | 09:17 AM
Damian0216's Avatar
I used to get o2 sensor codes 174 which is bank too lean. But that was fixed under warranty. And I don't think it can be covered by warranty I didn't get an extended warranty. I got the car new
Old Feb 3, 2012 | 09:19 AM
MMkay.
its an 08; i would go ask and try your luck especially if you bought it new? go to the same dealer
Old Feb 3, 2012 | 10:02 AM
ParaSurfer1979's Avatar
If you've driven that much you should have gotten the extended warranty. If you never use it, it comes back in a check to you refunded. but we're Monday morning quarterbacking on that subject. It could be bad gas or coilpacks too. Who knows until you go for a cool check-up.
Old Feb 3, 2012 | 10:19 AM
Damian0216's Avatar
Well I cleared the codes last night after I checked them..... I think ill disconnect ny battery today reset the ecu and see if they come back if they do, well I have a serious problem. I was just trying to see I'd it happened to anyone before and they figured out the problem. I know the dealer will just reset it to begin with and tell me come back if it happens again.... I will put a fresh tank of gas tonight most likely ill try to go to a shell instead of bp and see what happens.
Damian0216's Avatar
But I greatly appreciate the input from everyone
Old Feb 6, 2012 | 07:31 AM
are you the original owner of the car?
you said it was a six speed. could some one have over-revved the engine!?
pull the heads and see!
Old Feb 6, 2012 | 11:01 AM
I hate cars's Avatar
Agreed, misshift, bent valves.
Old Feb 6, 2012 | 04:22 PM
A-TLvic882's Avatar
04 A-TL 6MT SSM/E N/Navi
Look here https://acurazine.com/forums/3g-tl-problems-fixes-114/oil-consumption-846718/
it's Acura TL engine pattern failure.
Rueruerue
Feb 5, 2016 10:32 AM
TouringLow
Mar 21, 2010 03:09 PM
aRIff
Nov 9, 2004 12:12 PM
GSGOMEZ
Mar 31, 2004 07:45 AM
GSGOMEZ
24
Feb 25, 2004 02:29 PM
