All 6 cyclinders misfired....
Last night I started my car and all 6 misfired multiple times. I ended up with 14 codes and it all repeated 1-6 misfire and multiple misfire code. Any ideas???
I just did my sparkplugs sometime during fall of 2011 so I wouldn't think those would of gone bad already....
85k on the car 2008 tl type s
If you've driven that much you should have gotten the extended warranty. If you never use it, it comes back in a check to you refunded. but we're Monday morning quarterbacking on that subject. It could be bad gas or coilpacks too. Who knows until you go for a cool check-up.
Well I cleared the codes last night after I checked them..... I think ill disconnect ny battery today reset the ecu and see if they come back if they do, well I have a serious problem. I was just trying to see I'd it happened to anyone before and they figured out the problem. I know the dealer will just reset it to begin with and tell me come back if it happens again.... I will put a fresh tank of gas tonight most likely ill try to go to a shell instead of bp and see what happens.
justnspace (02-06-2012)
Look here https://acurazine.com/forums/3g-tl-problems-fixes-114/oil-consumption-846718/
it's Acura TL engine pattern failure.
Rueruerue
02-05-2016 10:32 AM
GSGOMEZ
03-31-2004 07:45 AM
GSGOMEZ
24
02-25-2004 02:29 PM
