Air vents smells like Putting Nose into Vacuum Bag
Old 04-19-2010, 02:22 AM
samplemonster's Avatar
Not sure what's up with my Fans but when I turn on the A/C it smells like someone just unloaded a bag of dust from a vacuum bag into my vents.
There's no visible dust particles, but the air feels intoxicating.
I'm not sure if it's only with the AC on, it can be triggered when AC is off and switching between -Circulate-in-car-air & -allow-incoming-air modes.
I replaced the cabin filter hoping it would fix it, but didn't do anything.
Old 04-19-2010, 07:06 AM
Registered Member
SouthernBoy's Avatar
A musty smelling venting in Honda products is fairly common. The primary cause is running your A/C on recirculate a lot instead of using the outside air setting (I know, this is the norm when first turning it on in the AUTO setting) or failing to dry out your evaporator.
About five minutes, or a few miles, before you arrive at your destination after having used your A/C for a while, turn it off, make sure you are on outside air, dash vents in use, and fan on high setting. This will help to remove some of the condensation from the evaporator coil and reduce the buildup of mold and mildew - the cause of the odor.
Old 04-19-2010, 10:11 AM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
also check the cabin air filter.....
when detailing the car i do the following:
1> turn the AC on full with the incabin circulation off !!!
2> close all doors and spray some lysol (from outside) into the air vents (right below the viper)
3> leave it like that for 5 minutes....and turn everything off
4> enjoy the mold free environment
Old 04-20-2010, 06:20 AM
thank you, i will try it out
Old 04-20-2010, 10:22 AM
Jesstzn's Avatar
This is the correct product to use after you change your cabin filter.
http://www.1z-usa.com/einszett_klima_cleaner.html
No sense just treating the sypmtom .. treat the problem.
uzzmaan
03-12-2024 10:03 AM
Yikes
05-03-2021 04:29 PM
cycdaniel
12-17-2019 10:58 AM
snorf
11-04-2019 06:44 AM
sputik
09-07-2015 01:40 PM
Quick Reply: Air vents smells like Putting Nose into Vacuum Bag
