Air in the steering fluid system
Steering was groaning especially in the morning when cold. I topped off the fluid which was low and replaced the two washers, but I'm still seeing bubble in in the reservoir when I turn the wheel to extremes.
What should be replaced next? Reservoir and hoses? Pump?
https://acurazine.com/forums/3g-tl-p...-scans-841134/
one of the largest and most common DIY’s on this sub.
rebuild the pump!
rebuild the pump!
rebuild the pump!
rebuild the pump!
It's possible I didn't adequately bleed out the air in the line after the washer replacement this weekend. Will continue to work on it to make sure the problem is not fixed already.
It also looks like you can buy a non-OEM pump on Amazon for $50 (e.g., /). Assuming they're not total crap, it seems like it might be worth it and less of a hassle to just swap out the pump.
DO NOT BUY ANY CAR PART, ESPECIALLY ONE THAT HAS MOVING PARTS, ON AMAZON!!!!!!
Just imagine if the internals of the PS pump (rotor and veins) explode while spinning ~6,000rpm. It's going to send metal shrapnel and shavings all throughout the hard lines, soft lines, reservoir & rack! In order to replace the steering rack, you need to drop the entire sub-frame, while simultaneously supporting the entire engine and tranny.
All to save ~$150 on a non-OEM part.
It's manufacturer is "Papa Parts"
You know when you get lost down a YT/Instagram wormhole and end up watching a video of some random dude in Bangladesh wearing flip-flops, shorts, a t-shirt and zero PPE, who's pouring a ladle of molten hot liquid aluminum into a sand mold that his buddy dug out of the ground with nothing more than a stick and a piece of bubblegum?? THAT'S exactly where this power steering pump was made and manufactured.
Now tell me; was it worth it?
OK, you guys have convinced me.
But it would have been worth $40 (I suspect the O-rings will come to $20 with shipping) to save me the time and hassle of disassembling the pump. Meanwhile, I'm seeing OEM pumps in the $400-500 range.
the OEM pump cover seal alone is $40!
https://www.oemacuraparts.com/oem-pa...al-91349r70p01
https://www.acurapartswarehouse.com/...9-R70-P01.html
I suppose you're going to tell me now that I can't buy non-OEM seals either!
https://www.aliexpress.us/item/3256805998576920.html
https://www.rockauto.com/en/moreinfo...&pt=7407&jsn=8
https://www.ebay.com/itm/185981706414
If the noise returns, I'll probably get this well-reviewed Sunsong seal kit ( ) and attempt the rebuild minus removing the shaft and replacing the thick inner seal.
The noise returned, so I did the rebuild minus the inner shaft seal (no impact wrench, so could NOT get the pulley wheel off).
Seems much better so far, but there's still a little faint moaning at times.
