too much power steering fluid
my brother filled it for me & the idoit overfilled it pass the upper level. ill drain it asap. just wasnt sure what the outcome would be if i left it overfilled
Don't worry it will overflow if anything just making a little mess. It wont hurt your PS system at all.
Main reason why there is an Air Gap there is because of that, When you full clock the wheel the PS Fluid tops off the Reservoir.
thanks, thats a relief. i would rather take some out now than have to clean up the mess in the long run haha
use a turkey baster ($2 at grocery store) to suck out the excess
YES it is bad to overfill for several reasons= max line has a purpose!!
Do use only Honda ps fluid to fill the system! its very picky
If you had to top it off, there is a problem somewhere = leakage
Often the orings at back of pump are responsible
haha yea i had the same idea. sucked it out with the turkey baster this morning.
& yupp, i used the honda ps fluid only.
if not in the diy there are plenty of threads on it- I have written it up in detail more than once, its also in your owner book,
free copy from acura here Acura Owners Site | Exclusive Knowledge, Service, & Benefits
simply remove upper hose at res and slip a piece of garden hose that just fits OVER the return line and secure together with hose clamps= or make a huge mess!!
Place catch bottle for fluid at other end of drain line
Place cardboard under front wheels to reduce friction
Start engine and turn wheels both directions to full lock- then back the other way,
repeat until ALL the fluid is out
turn engine OFF
This will NOT HURT the ps system at all- its acuras method!
just don't drive with it empty~
Now replace the return line, fill the res, restart engine and turn wheels lock to lock to push air out
ADD fluid as needed to res, it will keep getting sucked into the rack- where it lives
Options: drive around a bit or immediately do the full drain again while running, then refill = done!
its that simple!
getting right hose at hardware store is the hardest part, measure the outside diameter of return line
That hose size info is in threads on azine, look for them in problems section
turn engine OFF
its that simple!
mike from annapolis
May 7, 2017 08:21 PM
