Air box not tight on one corner
Old Aug 30, 2015 | 07:50 PM
bymotion's Avatar
Hey guys, I changed the air filter but one corner (closest to fusebox) of air box is not completely tight and I can't figure out why. I have changed filters many times before on many cars but this last bolt won't screw in and something is keeping it open. I am going to try again tomorrow when light is out but is there any harm in me driving my car to work with the airbox like this? I taped it with duct tape for now to not let any dirt or rocks in. Pic below.
Old Aug 30, 2015 | 08:44 PM
looks like bolt is stripped!
Old Aug 30, 2015 | 08:45 PM
bymotion's Avatar
^perhaps, but i can't even close the box all the way in that one corner. All other corners closed fine.
Old Aug 30, 2015 | 10:20 PM
because either the bolt is stripped or the plastic is stripped or the mount is stripped.
to fix it, you're going to need to extract which ever piece is stripped and replace it.
For now, maybe you can remove the bolt, and ZIPTIE the two pieces together.
Old Aug 30, 2015 | 10:21 PM
depending on how the air filter sits, it may still be filtering and doing its job, even tho there's a gap.
Old Aug 30, 2015 | 10:40 PM
bymotion's Avatar
I keep pushing the top and bottom airbox parts together at the corner and it won't close enough for me to ziptie it. I was thinking maybe the filter isnt in right but then the other 3 corners closed easily and the filter looked flat and in place when I placed it in.
Old Aug 30, 2015 | 10:43 PM
i'm too lazy to go look at my car real quick, BUTTT!!!!!!!
I believe that the AIR FILTER sits at the bottom there. so, even tho that one corner has a gap, the air STILL has to go over the filter to get to the throttle body.
Does this makes sense?
in short, I believe the filter is still doing its job even tho you have a gap in that corner.
Old Aug 30, 2015 | 10:46 PM
bymotion's Avatar
I really hope this is the case! My concern is if the gap is above the filter and all the engine dust/gunk will bypass it and going into the hose/sensor. If anyone can verify based on that picture that would be great haha
Old Aug 30, 2015 | 10:51 PM
get to know your car!
take off the other three remaining screws and see if the air filter sits at the bottom, then use reasoning and logic to determine if you're okay or not!
that's what I would do, anyway.
Old Aug 31, 2015 | 08:19 AM
polobunny's Avatar
Registered Bunny
Can't say anything that hasn't been said by Justn. Open it, check why it's not closing properly. On mine one of the bolts broke and it still holds just fine with 3 left...
Old Aug 31, 2015 | 09:42 AM
bymotion's Avatar
Thanks guys. I'll open it up after work and see whats going on.
Old Aug 31, 2015 | 05:00 PM
bymotion's Avatar
Just popped that sucka back in. thanks for the help guys
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Kitsune13
Sep 24, 2015 02:25 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
