AEM v2 filter placement
Old Mar 15, 2011 | 08:56 AM
Biggi_e's Avatar
FRESHINNOVATION NBP TL-S
the other day i was installing my 3k Hids for my Foglights. i noticed the filter is pushed up real tight into my foglight where the harness and back side of the bulb are. could this be a potential problem? is there a way to fix this?
anyone have pics of their aem v2 installed by the filter area? Thanks
Old Mar 15, 2011 | 09:01 AM
SharksBreath's Avatar
BANNED
do you have OEM fogs? accord fogs?
here is a pic of when i installed mine, and i had no problems with fitment sourrounding the foglights. make sure the top of the intake (near manifold) is pushed in as far left as it'll go. i even have a p2r spacer and had no problems.
Old Mar 15, 2011 | 09:34 AM
Biggi_e's Avatar
oem foglights that came with my 07 type s.
hmm my intake filter is like jammed against my foglights, nothing like yours at all..
also did you make that braket?
Old Mar 15, 2011 | 09:37 AM
BANNED
i've also got an 07 type-s. your filter should not be jammed against anything...got any pics?
n yeah i bought the intake second-hand, so i assumed it was missing a bracket or something. the homemade one gets the job done tho. just a piece of thick sheet metal and i measured and drilled 2 holes on each side, then used a rubber mounting grommet and washer/bolt...keeps the intake in place with adaquete flexing.
Old Mar 15, 2011 | 09:41 AM
Biggi_e's Avatar
i dont have any pics but i will try and take some when i have time to mess with the car again.
i def. need to make a bracket for the intake since might is only connected from the top and thats it.
also is there a way to adjust the aim of my foglights? im not sure if its because of my filter from the intake or not but my drive side foglight output is higher than the passenger side.
appreciate the pics sharksbreath
Old Mar 15, 2011 | 09:46 AM
BANNED
i'm guessing your foglight is probably angled-off bc of the filter hitting the housing. that is a possibility.
i replaced my OEM fog lights with ddm tuning 5000k and they are straigt as can be (just like the OEM ones)
were your fog lights aimed differently before you installed the new HID's? you shouldn't have to adjust anything because it's just plug n play yanno?
Old Mar 15, 2011 | 09:59 AM
Biggi_e's Avatar
i honestly dont know if it was angled off prior to me putting in my hids. im using ddm tuning 3000k for my fogs.
might have to make a trip to bmore and have you check my shit out LOL
Old Mar 15, 2011 | 02:25 PM
paperboy42190's Avatar
dude dont worry about it. mine is the same. i noticed it a couple weeks when i pulled out my fender liner a bit i saw that my filter was pretty much touching the back of the foglight bulb. no issues though.
Old Mar 15, 2011 | 02:28 PM
Biggi_e's Avatar
well it would still be a good idea to make a bracket for the intake so it wont move around so much.
Old Mar 15, 2011 | 02:37 PM
BANNED
yeah you should def have a bracket there, i mean...there is a mounting bracket attached to the AEMv2 for a reason.
and if your fog light housing is pushing against your filter for an extended period of time, it'll cause your filter to lose it's shape with a nasty indentation. i've seen it numerous times.
Old Mar 15, 2011 | 02:39 PM
Biggi_e's Avatar
i think when my friend installed the aem v2 for me, he couldnt find a spot to fit the bracket on since its not originally made for the TL. ill have to double check everything.
as for the filter, i already have indentations...LOL
Old Mar 15, 2011 | 02:49 PM
BANNED
^that's exactly what happened to me, although i thought i was just missing a part since i bought it used.
but that makes sense, that's why i made the bracket.
Old Mar 15, 2011 | 03:42 PM
Jesstzn's Avatar
Prolly the reason your having clearnce issues.
Old Mar 15, 2011 | 03:43 PM
BANNED
^yeah but i have the same intake and have no fitment issues whatsoever.
Old Mar 15, 2011 | 03:45 PM
Jesstzn's Avatar
Yours wasn't made for the TL either?
Old Mar 15, 2011 | 03:52 PM
BANNED
^the AEMv2 that everyone gets was originally made for a honda accord...but it fits the TL as well.
i forget the part number, but if you look it up...it just says for the accord.
LeVeL
Oct 18, 2015 04:19 PM
lanechanger
Oct 13, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
kingbharj
Sep 25, 2015 07:25 PM
