'04 TL Doors and Remote Problem PLEASE HELP!
Old Mar 7, 2011 | 06:08 PM
vtec22's Avatar
I finish my work today come up to my car unlock it get in and start the car, it showed on the gauge screen that the 2 right passanger doors the front and back are opened. I opened them and closed them again nothing... . I got out of the car tried locking it it didn't lock at all. I got back inside he car turned it on it still showed me the doors are open. I tried to close them from the inside the left driver's and left passanger's closed the 2 right one's did not.
So I went to a hardware store to pick up a new battery for my remote. As I was driving the car on the way to the store the back right passanger door showed closed but the front was still open. I bought a new battery put it in and tried it out still nothing worked. Now I am worried! I don't know what the heck to do now. I just parked my car and locked it manually from the inside and went home.
New Battery didn't help.
Trunk opens and all doors open
2 Righ doors dont close and from the inside what should I do guy's?
Old Mar 8, 2011 | 07:24 AM
vtec22's Avatar
I went to work today at, and the car couldn't be unlocked or locked at all! I had to use my key to get in and I started the car and went to work. Funny thing is the alarm was on while I was driving and my dash gaige lights did not change to brighter. My turning signals didn't work as well, this is soo weird.
Old Mar 8, 2011 | 10:22 AM
vtec22's Avatar
ANYONE LOL! blyat pohuisti vse vi!
Old Mar 8, 2011 | 11:43 PM
Actrite04's Avatar
TEAM INFIDEL!
It is more than likely your door switch could be possibly bad. Also possibly a blown fuse
Old Mar 9, 2011 | 07:20 PM
3g_ace's Avatar
I don't know if Acura's have this issue, but in fords I have seen those sensors get dirty and not work properly. Pick up a can of electronic parts cleaner and spray the hell out of the door latch, maybe it will clean those and fix the issue , couldn't hurt. I think when a door is registered as open it wont lock so maybe this is intertwined with your keyfob issue
And when you drove with the alarm on it makes sense that stuff didn't work, I don't think its supposed to when someone steels your car!!
Good Luck
Old Mar 11, 2011 | 05:08 AM
vtec22's Avatar
well what do you know, my car's alarm went off 4 times between 2-4:20 am.... jesus christ. So I was unlocking it and then locked it and it was raining not too long ago, pretty heavy rain... . So i left the car unlocked until I go to work. I wake up and about to go to work tried to lock my TL and there you go again it's not locking what the f*** are you serious..... I am sure that this issue started again.
Maybe the water is getting in some ecu or fuses, maybe something else... Can it be my MultiFlex unit? Guy's help me out here this is getting me annoying!
Old Mar 11, 2011 | 05:10 AM
vtec22's Avatar
Please
Old Mar 13, 2011 | 12:42 PM
3g_ace's Avatar
It could be a bunch of different things, sounds like you have an aftermarket alarm? I would start with that, they can cause all sorts of strange happenings
Old Mar 13, 2011 | 08:16 PM
vtec22's Avatar
I have Original Alarm in my TL, it has never been changed.
I visited my mechanic today and we diagnosed the car for like 2 straight hours. There were more than 20 codes that had an issue with the Multiplex Integrated Control Unit (MICU) it's built-into the under-dash fuse/relay box... . He's going to replace the multiplex unit by the driver's side fuse box. Hopefully that fixes the problem
04 TL w/Navi Custom SideMarkers
Old Mar 13, 2011 | 09:12 PM
csmeance's Avatar
Be sure to make sure that the area isn't damp!
Old Mar 15, 2011 | 05:44 PM
vtec22's Avatar
Just got the car back and everything works perfectly fine!
If anyone has this problem DO NOT go for your Door Actuator's or anything like it... Just get the new MICU Fuse Box 192.00 w/tax, $250 with install.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Azonics
Sep 22, 2015 05:28 PM
EE4Life
Sep 11, 2015 10:13 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
