Acuraziners chime in plz!
Old Jun 27, 2012 | 09:50 AM
kasualballn's Avatar
Whats up Aziners I tried doing my own research on this issue the last week. I want to bring the issue here to get some advice.
My Car: 07 Base
Story: I Took My Car to Jiffy Lube got an oil change they pointed out a hole in my intake boot. The Car was throwing these codes before oil change.
P145C
P0497 Evap Emission Low flow fault
Car still ran fine at this point
soon it started having rough acceleration and hesitation through the RPMs
I replaced the intake boot and air filter. That didnt help and the car is now having this code.
P0108 Map/Baro Circuit High Input car started all symptoms after this code.
Any help would be Appreciated before i take it to the Stealership Thanks.
Old Jun 27, 2012 | 10:03 AM
AcuraIntegTL's Avatar
keep it clean
Have you tried to reset your ECU after getting the intake boot fixed? Also, double check to ensure everything is nice and tight. Had a roomate that was getting a lot of air map codes from his Supra, and it turned out to be a loose intake clamp.
FYI: This will probably get moved to problems and fixes.
Old Jun 27, 2012 | 12:14 PM
LoveMyTL-S's Avatar
^^^ Yeppers.......
Old Jun 28, 2012 | 08:34 AM
How do you reset the ECU? and everything is tight also.....
Old Jun 28, 2012 | 08:37 AM
SharksBreath's Avatar
BANNED
^unhook your negative battery cable for a few minutes. then hook it back up.
^simply disconnect the battery for a few mins
Old Jun 28, 2012 | 08:47 AM
TheLowLife's Avatar
Make sure you have your radio code before you unhook the battery or you won't be able to listen to your tunes!
TheLowLife's Avatar
Oh, and if you have navigation, you'll need the navi code as well..
Old Jun 29, 2012 | 12:51 AM
I hate cars's Avatar
Anything before the throttlebody will have no effect on the way the car runs. Only on a MAF car will it have an effect. The MAP sensor could easily make the car run bad. Unplug it and visually inspect first. If it starts throwing a lot of random codes, the battery and grounds are usually the first place to start.
Old Jun 29, 2012 | 12:39 PM
Do you mean unplugging the battery?
oyayjoe
Jan 1, 2019 10:17 PM
mugen_kid
Nov 13, 2015 10:38 PM
MyGuti
Sep 12, 2015 06:52 PM
oyayjoe
Sep 12, 2015 04:40 PM
DRR98
1G RDX Problems & Fixes
Sep 2, 2015 10:52 AM
