Acura TL 07 problem
Acura TL 07 problem
so I tested my alternator earlier this week due to my car dying every morning it was bad so I just replaced it. Battery tested fine afterwards with new alternator, but I went to turn on my car and the lights on the dash seem to glitch and seems like the car didn't wanna start even though it did . Any ideas ? HFL maybe? If not what else could it be
Seriously? Not sure where you heard that but if the HFL is unplugged, there is no way on this earth it was consuming power from the car's battery. Whatever idiot told you that should be ignored,
Yes, there was a class-action lawsuit with the HFL issue. I don't know what the outcome was, or if there even was an outcome. Either way, pulling the fuse or unplugging the HFL will fix it. It obviously can't continue to draw power from the battery if it's unplugged. That would be like your vacuum running after you unplug it from the electrical socket. That's some new technology there! Well, actually, they have "wireless charging" for phones I believe, but not yet continuous high-wattage wireless power. Maybe we'll get there one day
It would be like wi-fi but for power!
Is the battery healthy? If it's died several times, it could be sulfated which reduces output considerably. It's bad to let lead-acid batteries die. It can shorten their life very quickly.
Here's a thought: it could be something else drawing power IN ADDITION to the HFL..
time to break out the multimeter and start a parasitic draw test :
OR could be this.. :
time to break out the multimeter and start a parasitic draw test : https://www.youtube.com/watch?v=KF1gijj03_0
Your option is to get the issue properly diagnosed and stop throwing money and parts at an undiagnosed problem.
Here's the thing, how much have you already spent in repairs which ended up not fixing the issue? If you are unable to use a multimeter to figure out the source of the problem, then spending $150 on a diagnosis is cheap compared to buying and installing a bunch more parts.
bama boy
Jan 26, 2010 08:03 PM
jamesjinlee
Sep 16, 2003 08:39 PM
chowan24
Apr 30, 2003 07:49 PM
