terminals on wrong side
Old Jan 8, 2019 | 11:14 PM
CAM909RON's Avatar
I really screwed up this time i took my battery out to fully charge it and when i put it back i put the terminals on the wrong side of each other now nothing will turn on in my car the battery is fine but i dont know where to start any suggestions would help
Old Jan 9, 2019 | 01:08 AM
DesertMistTL's Avatar
blew some fuses
Old Jan 9, 2019 | 01:16 AM
Midnight Mystery's Avatar
Null and proud of it
Is this any better than jumpstarting backward.
Old Jan 9, 2019 | 09:53 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Check all your fuses, both underneath the dash and under the hood. If any blew, replace those.
Old Jan 9, 2019 | 06:53 PM
CAM909RON's Avatar
Can i check them with a voltage meter
Old Jan 9, 2019 | 07:19 PM
sure.. turn your volt meter to the "continuity" mode and test all the fuses to make sure they're blown.
You may have just blown the main 100/120A fuse in the underhood box..
how the hell did you even put them backwards, the ground (negative) cable is purposefully short to stop this from happening..
Old Jan 9, 2019 | 07:29 PM
CAM909RON's Avatar
It was dark outside and i had no flashlight
Old Jan 9, 2019 | 08:06 PM
Jackass's Avatar
I think his point was the cables shouldn't even reach the wrong sides of the battery....unless you have modified the cables somehow. I know my cables just barely even reach the correct terminals....didn't think it was even physically possible for them to be crossed.
Hopefully it is as simple as one of the bigger fuses being popped.
Old Jan 9, 2019 | 08:11 PM
CAM909RON's Avatar
What i had did was put the battery in reverse meaning the neg was by the pos and the pos by the neg
Old Jan 9, 2019 | 09:30 PM
Welp check your fuses in the underhood box
Old Jan 12, 2019 | 12:44 AM
CAM909RON's Avatar
it was the 120/70 amp fuse
Old Jan 16, 2019 | 04:55 PM
i'll give myself a cookie and a pat on the back
Old Jan 17, 2019 | 07:19 AM
CAM909RON's Avatar
Talking
I'll give myself a cookie and a pat on the back
appriciate u the acura world wouldnt go round with out u
mav3556
Jul 8, 2007 07:20 PM
njzprettyboy
Jun 7, 2007 03:13 PM
97BlackAckCL
Apr 29, 2005 05:57 PM
PiMpiN wHITe Cl-S
Sep 15, 2003 06:06 AM
