accord fogs AGAIN !!!!!
NEW CHECK ME OUT !!!
hey i just try putting in my fogs after looking an reading up on all these forums but for some reason they just wont fit PLEASE anyone send me more detailed pics on this DIY install .......
Check out the 3G garage...if not check out threads started by myself and sixsixfour and there's another member too...very detailed...they def. don't just fit right in without a dremel, some creativity and some patience.
Jeremy..
google
acurazine 3g tl accord bumper fogs
Jeremy..
I quoted my post from my buildup thread here: https://acurazine.com/forums/showthr...=715481&page=2 .. there is more info on my install of my fog lights there.. but I only quoted what you said you needed, which was a pic of the actualy cutting required.. some people cut less then me, but this worked for me..
I cut from the top and the bottom. I also cut a SMALL slit on the right side so that the corner of the fog light housing could slip in a little. I also trimmed the fog light housing a little bit in the upper right hand corner so that it could fit into the slit I cut. This way it is being held in by the slit. I DID NOT use silver bracket that came with it. I Only used the bottom hole in the housing to screw onto the bumper. Between the grill, this screw, and the aspec lip, the slit I made to catch the upper outter most corner, this fog is not going anywhere lol..
And a shot of the grill (I had to cut a little bit more to get it to fit properly after these pics, but by following this you should be close to what you need):
Notice how far the cut is from the top brcket and how close the cut is to the bottom bracket.
Here is a shot of how close I had to cut to the bottom of the grill. I had to cut like 1mm more to get it to sit really flush:
And here is a pile of garbage left after the install lol:
Looks sooo good!!
Looks sooo good!!
adreano17
09-29-2015 08:48 AM
