AC Diagnostic Screen
Old Jul 31, 2015 | 01:48 PM
Indy04TL's Avatar
Remind me how to pull up the AC diagnostic screen "88" for an 04 TL Navi.
As always, Thanks!
Old Nov 3, 2015 | 08:43 PM
scottn3's Avatar
Scotch
Can someone provide this info? I could use some help...
Old Nov 3, 2015 | 09:07 PM
truonghthe's Avatar
I believe you have to press and hold Map/Menu and cancel at the same time until the hidden menu appear for TL with nav unit.
Old Nov 4, 2015 | 01:57 PM
Vlad_Type_S's Avatar
Registered Bike Offender
Originally Posted by Project_CLean
I don't know if this will help but worth a shot for some of you, there was a thread on this a while back, where i listed these same codes, but i can't seem to find it.
THESE, are all trouble codes with the Climate control system. To get into troubleshoot mode, you have to :
1)Turn ignition switch ON
2) Hold the OFF button on the Climate Control Panel
3) *WHILE HOLDING THE OFF BUTTON*: Press the "Recirculation" button 5 times within 10 seconds.
4)This should begin the diagnostic,and the temperature settings will light up determining if there is something wrong: (see attached pictures).
5)Depending on the section lit up, there's a letter assigned to each section, so using the list below,you can determine what is wrong.
DTC (Temperature Indicator Segment)
Detection Item
A
An open in the in-car temperature sensor circuit
B
A short in the in-car temperature sensor circuit
C
An open in the outside air temperature sensor circuit
D
A short in the outside air temperature sensor circuit
E
An open in the sunlight sensor circuit
F
A short in the sunlight sensor circuit
G
An open in the evaporator temperature sensor circuit
H
A short in the evaporator temperature sensor circuit
I
An open in the driver's air mix control motor circuit
J
A short in the driver's air mix control motor circuit
K
A problem in the driver's air mix control linkage, door, or motor
L
An open in the passenger's air mix control motor circuit
M
A short in the passenger's air mix control motor circuit
N
A problem in the passenger's air mix control linkage, door, or motor
O
An open or short in the driver's mode control motor circuit
P
A problem in the driver's mode control linkage, doors, or motor
Q
An open or short in the passenger's mode control motor circuit
R
A problem in the passenger's mode control linkage, doors, or motor
S
A problem in the blower motor circuit
Here you go
4drviper
Apr 23, 2025 07:13 PM
ValdezQ26
Oct 1, 2015 04:48 PM
hashbrown
Sep 29, 2015 12:13 PM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
TL14
Sep 24, 2015 04:37 PM
