AC Condensation
Check the condensate drain:
http://www.triadautoblog.com/04-08-a...n-can-kill-the
If you take your car to places like jiffy lube and stuff, some tech's put screws in the end of the line to plug it so they don't get dripped on when doing an oil change.
I checked behind the wheel on the passenger side and couldn't find it. Can anybody be more specific? If you can take a picture of it from you car, that'd be great. Thank you.
Look under the car behind the right front wheel under the front of the passenger side door, but under the car a couple of feet. If you see no liquid on the ground after the A/C is running for a while, get it up in the air and have someone check the drain to be certain is open.
So apparently i was looking at the wrong area haha. Checked behind the wheel after i got home earlier and saw water under the car. Jacked my car up and checked the tube to make sure it wasn't blocked. Thanks guys!!
Good deal. I've had a couple of cars end up with 4" of water in the rear floorboard, just from AC condensation. Amazing how much liquid drains out of an auto AC......
HASTA LA VICTORIA'
Does anyones center console get really cold too.. when i have the a/c on for awhile the center console and metal garnish get really cold.. idk if my vents might have came off or are loose
Fibonacci
Money & Investing
01-23-2009 12:16 AM
keepingitclean
04-15-2005 02:10 PM
