AC compressor not turning on - looking for insights
Hello gurus. My ‘04 TL with 178k miles did not blow any cold air the first time i turned on the AC the other day ( after not turning it on all winter). I also noticed that the click / faint ‘woosh’ sound doesn’t happen when i push the AC button on. Does that mean the compressor needs to be replaced or does the compressor cut off / not activate if the Freon is super low / empty. Obviously hoping for the latter as a compressor replacement seems costly. The fan blows just fine. Thank you!
As mentioned, the culprits may include low freon, bad compressor clutch, bad AC associated relays, or bad pressure switch.
You can jump the clutch relay to check the compressor clutch.
Following this so far. My compressor clutch seems to engage and so the relay is fine. But there is no cold air. I checked the coolant level and the refill bottle goes to red and tells me consult a technician. I can tell the compressor engages because of an increase in RPM when AC is turned on. Any ideas here? Thanks!
if pressures are in the red you may have a clogged a/c line or debris caught in the evap/condensor or txv valve...
tsx504
1G TSX Problems & Fixes
03-16-2015 10:22 PM
DerrickM
04-20-2005 01:05 AM
