A/C Compressor not turning on
Old Jun 2, 2006 | 09:31 PM
wjk's Avatar
wjk
Unhappy A/C Compressor not turning on
All of a sudden my compressor doesn't want to turn on. Refrigerant level is fine. Any thoughts what to check? Thanks!
Old Jun 2, 2006 | 09:48 PM
natesezgoblue's Avatar
fuses??
Old Jun 3, 2006 | 06:25 AM
wjk's Avatar
wjk
Originally Posted by natesezgoblue
fuses??
The fuse under the drivers side dash is fine. Any other fuses? Or relays?
Old Jun 3, 2006 | 12:56 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Under the hood
Old Jun 3, 2006 | 01:26 PM
SupraManAG's Avatar
One custom CL
check your fuses
the compressor gets one feed
you need to make sure your line isnt grounding out or cut off like in my case
its a pain in the ass but you might need to find a electrical professional to save yourself the headache
where do you live? maybe i can hook you up
Old Jun 3, 2006 | 01:34 PM
wjk's Avatar
wjk
Originally Posted by SupraManAG
check your fuses
Are there any related fuses other than the driver side ones? Any relays? If so, where are they?
I live in Branford, CT. I've got an appointment for Monday with a good guy, but I want to give him a heads up if possible.
Thanks!
(An A/C specialist did a very quick look and said he didn't think it was the compressor, and after hooking it up said the refrigerant level was fine.)
Old Jun 3, 2006 | 01:36 PM
SupraManAG's Avatar
One custom CL
the compressors rarely go
its the feed from the unit inside the car that might go bad somewhere
01CLOwner
Oct 9, 2015 01:07 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
Sep 17, 2015 09:01 PM
lovic87
Sep 15, 2015 06:07 PM
theinsvnity
Sep 10, 2015 10:22 PM
