AC causing "Whoooooo" Sound
Old Jul 26, 2007 | 12:25 PM
Grinch80's Avatar
I noticed when my AC is on in my 07 TL AT, during a moderately to super hot day, and I hit the accelerator in certain circumstances, a low "whoooooo" sound eminates from what I believe is the left front side of the car. I know it's the AC because when I manually turn the AC off, the sound completely disappears.
Could this be the AC compressor having to work extra hard on a hot day? Anyone else experience this problem? I'm thinking of taking to the dealer, but want to make sure the behavior is not normal first. Thanks!
Old Jul 26, 2007 | 01:03 PM
twigglius's Avatar
we live in a simulation
It's all about the woooooo wooooooo!
woooooo woooooooo
Old Jul 26, 2007 | 01:58 PM
Grinch80's Avatar
[QUOTE=twigglius]It's all about the woooooo wooooooo!
Uh, thanks, but that doesn't help me much.
Old Jul 26, 2007 | 04:35 PM
csmeance's Avatar
is it high pitched or low, if it high, try seeing if you turn off the recycle air that it goes away. Also see if you lower a rear window so air can pass thru and do it, this will tell if there is a pressure problem.
Old Jul 26, 2007 | 05:21 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Well the a/c compressor is on the right side of the engine bay, and you believe that the sound is coming from the left side....
Old Jul 26, 2007 | 05:39 PM
Grinch80's Avatar
Well, I'm not totally sure it's coming from the left side. Could just be my perception.
The sound is more low then high, I'd probably describe it as mid-range.
I'll try the air recycler and rear windows, thanks for the tip. Will report back...
Old Jul 26, 2007 | 06:23 PM
timmahh's Avatar
it's me, Alan Rickman.
That happens to me when that Gwen Stefani song comes on .. "woooo ooooo... eeeeee ooooo"
As mentioned above I would try turning recirc. on and see if the issue disappears. It sounds like it might be the right combination of outside wind speeds / vehicle speed / air pressure inside the car to cause a wind noise.
Old Jul 27, 2007 | 09:40 PM
Grinch80's Avatar
No go. It was 90 here today and the AC sound kicked in good. Taking my TL to the dealer next Tuesday.
Old Jul 28, 2007 | 05:58 PM
iknoweverything's Avatar
90% of the time that noise is caused by the expansion valve
Old Jul 29, 2007 | 12:01 AM
Grinch80's Avatar
So is that a fairly easy fix for the dealer to make? Could I do adjust it myself?
Old Sep 4, 2007 | 03:52 PM
dank104's Avatar
i think i have a similar issue...my ac makes a whistling or hissing type of sound esp when it is on low. and sometimes it get's louder as i accelerate, and sometimes it doesn't make a noise at all. i took it to the dealer today and told me it's the expansion valve noise and that's it's normal. i don't buy it though. if it keeps making this noise after another 1k miles, i'm gonna take it in again or go to another dealer. i have a 2007 with 2k miles and it's made that noise since i bought it.
Old Sep 5, 2007 | 06:55 AM
Aznpersuasion's Avatar
Supercharged 2005 TL NBP
haahah, that was a funny video haha
~Jason
Old Sep 10, 2007 | 07:10 PM
07typeS's Avatar
07typeS
Not to mention the careless and wreckless, crossing the center line and running the stop sign all while making that stupid sound. lol
4drviper
Apr 23, 2025 07:13 PM
mlody
Dec 4, 2019 02:11 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
juanrl
Sep 29, 2015 03:25 AM
spoiler900
Sep 23, 2015 04:41 PM
