ABS Sensor and Lower Ball Joint HELP
Old Sep 3, 2012 | 12:30 PM
bobsfree76's Avatar
8th Gear
So, I'm changing my lower ball joint and cv shafts this weekend and ran into a little problem. I trying to get the knuckle off so I can remove the ball joint but the ABS sensor is stuck. I unbolted the 3 bolts holding it in but it is still stuck. I saw removal instructions for the front knuckles and it looks like the sensor comes right out. I'm worried about breaking the wire. Anyone done this before that had the same issue. Also if the sensor wire breaks how easy is it to replace. Thanks for any info.
Old Sep 3, 2012 | 12:44 PM
SpiderX1016's Avatar
Twist the sensor around the base. Carefully use a flat head screwdriver if you have to. Then pry it out.
Old Sep 3, 2012 | 02:00 PM
bobsfree76's Avatar
8th Gear
Ok so that didn't work. I ended up breaking the sensor. That's ok I can figure that out later. I'm no longer worried about that. Now I cannot get the bolt through the strut fork it is like fused on there. I tried hammering it and I put PB Blaster. Anyone have any idea how to deal with that.
Old Sep 3, 2012 | 03:06 PM
Pry up and down on the control arm and hammer it out.
Old Sep 8, 2012 | 01:42 PM
bobsfree76's Avatar
8th Gear
Angry Still having problems
Ok guys this whole project has become the biggest pain in the ass. I can't get the bolt out that goes through the strut fork. I used some heat off my map gas torch and all that accomplished is the is spun the bolt around and the bushing is still attached. So I have to change the bushing which I found a Advanced for $20. But the bolt is still in there and I cannot hammer that bitch out. Also I am changing the lower ball joints and they are pressed in but it seems that the plate or shield or whatever it is is in the way of pressing the ball joint out out. The plate is on the back of the wheel bearing. I have done all sorts of service before including the 105K service. So this should be easy. Please HELP ME. Any tips or suggestion would be great. Thanks Guys
Old Sep 8, 2012 | 02:54 PM
jdm_BOB's Avatar
6th Gear
Do you even need the knuckle ring. Also is it true that you need to replace the whole knuckle and ball joint is not replaceable?
RobbDizzle
Oct 15, 2015 11:16 AM
Specmiata82
Sep 30, 2015 10:04 AM
hrothgar02
Sep 28, 2015 11:08 AM
Brandle34
Sep 23, 2015 07:20 PM
0opie
Sep 22, 2015 04:15 PM
