6MT Transmission Flaring!!!
Hey guys I have a 2008 Type S 6MT with 112K miles and about two weeks ago I changed my tranny fluid with Acura Tranny Fluid and for the past two days when I am on 5th or 6th gear and try to speed up on the highway the RPMs spike a little and then settle after a few seconds. It only does it on 5th and 6th gear. My question is why would it start doing this after changing the tranny fluid? I read great things about GM Synchromesh Tranny fluid and wonders this fluid has done to 6MT owners, do you guys think I should change the fluid to that GM Fluid and see if it would cure this flaring. I changed the fluid because I didnt know how long its been since the fluid was last changed by the previous owner.Also car switches in and out of gears smoothly. Any help would be great. Thanks
Not sure what you mean by flaring... However, RPM spiking to me sounds like your clutch is slipping. The reason why I changed to the GM fluid was the gear grind going into 3rd. Once I replaced the clutch and used the GM fluid it's never been better.
My RPM increases were straight the clutch it got worse and was brutal!! Good luck
That's just for the clutch. Have a look at the flywheel price too...it's not as friendly. But if your doing the clutch you'll kinda want to get both while your in there.
Did you mean to say Honda manual transmission fluid? As far as I know, Acura only carries and labels automatic transmission fluid - which will probably cause damage to manual transmissions. I am not trying to troll or anything, I just have not heard of an Acura labeled MTF before.
Anyways, good luck with the clutch change Godfather.
Ok guys so I had the Acura Tech look at my car and he told that my clutch needs replacement and told me to go buy the clutch and flywheel from LUK since its alot cheaper than getting it from the dealer even with his discount. He told me that the part numbers are CLUTCH = 08-047 Flywheel = DMF105 and that its the same parts I would buy if I got them from Acura. What do u guys think is he correct on that??
Again these are the part number's for Type-S 6MT CLUTCH = 08-047 Flywheel = DMF105 and the guy over the phone told me that LUK is what is packaged in the Acura/Honda boxes just alot more.
joflewbyu2
Oct 8, 2015 11:16 AM
