3x3 auto trans flush
Old May 7, 2010 | 10:38 AM
pohljm's Avatar
Does anyone have the scans from the service manual regarding the 3x3 auto tranny flush method? I would like to give them to my mechanic. It seems that he was not able to get anywhere close to 3 quarts out. I would like to have the acura instructions that indicate that. I have searched the garage but have not found the instructions.
Old May 7, 2010 | 11:06 AM
nfnsquared's Avatar
Originally Posted by pohljm
.... I have searched the garage but have not found the instructions....
Dude, how hard did you search? Look again....Hint C25, C26.....
Old May 7, 2010 | 11:12 AM
i_love_cars's Avatar
There's a DIY on this, I believe, but you probably aren't going to find Acura tech documentation on this because Acura's standard procedure for this is just a 1x3 drain/refill. They don't do a 3x3 flush if you take it in for a trans fluid change.
If you press them they may use a pump to get all of it out, but definitely they won't do a 3x3 - at least that's what Acura Brookfield told me here in Wisconsin.
If you aren't getting 3 quarts out then I don't know what else to do besides use a pump to extract everything by force. I've done several 3x3 flushes and always get 3 quarts (give or take)...
Old May 7, 2010 | 11:26 AM
nfnsquared's Avatar
Originally Posted by i_love_cars
There's a DIY on this, I believe, but you probably aren't going to find Acura tech documentation on this because Acura's standard procedure for this is just a 1x3 drain/refill. They don't do a 3x3 flush if you take it in for a trans fluid change....
FYI, not true. Read C-25.
Old May 7, 2010 | 11:27 AM
pohljm's Avatar
I saw those, but i was looking for the 3x3 instruction, but I will use the manual scans from here.
Old May 7, 2010 | 11:36 AM
nfnsquared's Avatar
Reread C-25 and the link provided by Ron A in bold letters at the top of the post. You'll need a lift or jackstands for this.
Also, C-26 is a modified version (you actually drive the vehicle between drain and fills instead of shifting on a lift).
Old May 7, 2010 | 11:52 AM
S PAW 1's Avatar
It's SOP at Lindsay Acura in Columbus, Ohio.
3X3 all the way
Old May 7, 2010 | 04:41 PM
3X3 all the way
I'm so ashamed of my stealership right now ;(
Old May 7, 2010 | 04:46 PM
chrissakes I'm blind. I've always used the C-026 user-made DIY with all the pretty color pictures
C-025 does indeed show tech docs, although doesn't list doing the drain/refill 3 times as SOP which is still beyond me.
Old May 8, 2010 | 05:17 AM
nfnsquared's Avatar
...C-025 does indeed show tech docs, although doesn't list doing the drain/refill 3 times as SOP which is still beyond me.
Yeah it does (the service bulletin):
"8. Set the parking brake, and repeat steps 2 thru 6 two more times."
Old May 11, 2010 | 10:34 PM
djarovsky's Avatar
January 2008 Acura Service News- page 1
Check Out the Latest Word on A/T Flushing
http://www.in.honda.com/Rjanisis/pubs/SN/B080100.PDF
Individual Acura Service News article:
http://www.in.honda.com/Rjanisis/pubs/SN/B08010A.PDF
Old May 11, 2010 | 11:10 PM
nfnsquared's Avatar
That is the same link that is in 3G Garage C25 already mentioned above....
Old May 14, 2010 | 04:32 PM
scots11's Avatar
Here it is..... https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
TypeS860
Jan 10, 2026 11:11 AM
LeVeL
Oct 18, 2015 04:19 PM
hashbrown
Sep 29, 2015 12:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
hpfiend
Sep 27, 2015 06:59 AM
