3rd Gear TSB Question
Old Feb 23, 2011 | 08:23 PM
SDSilverM3's Avatar
I did some searching but couldn't find a definite answer.
If my car does not fall within the VIN# range of the recall, is it still susceptible to the issues with the rough engagement/popping out of 3rd gear?
Has anyone else outside of the VIN# range experienced those same symptoms or is it something that should be considered fixed?
Thanks in advance.
Old Feb 23, 2011 | 08:28 PM
Replace your existing MTF with GM Syncromesh fluid friction modified.
it completely got rid of my third gear pop out problem.
Old Feb 23, 2011 | 08:30 PM
stvtec's Avatar
'06 WDP TL 6MT
Yeah, if your car is not in the VIN range then I presume it already has the updated gearset? There must be a reason why it isn't included, and therefore the dealer is not going to want to do anything for you. The GM fluid is supposed to be the magic fix. I have 3 quarts sitting on my night table right now.
Old Feb 24, 2011 | 12:00 AM
SDSilverM3's Avatar
Thanks for the responses. Should I still use the GM Syncromesh fluid even if my car has the updated gear set? I'm guessing I should anyway since most 6mt owners swear by it.
Old Feb 24, 2011 | 07:11 AM
SouthernBoy's Avatar
Registered Member
At least consider Amsoil's product. However, if you can get the GMSFM fluid (part #12377916), this is the one you want to use. For what it's worth, my '04 TL has just about 82,000 miles on it and it has never had any of the transmission problems reported on these forums. Not one. Granted, I did start using GMSFM fluid at around 15,000 miles, but it was just fine before that.
Old Feb 24, 2011 | 09:08 AM
user 0579729724's Avatar
09 Accord Coupe 6 Speed
Yup, I swapped the MTF out of my 09 Accord V6 6MT and it's smooth as silk.
http://www./forums/showthread.php?t=...GM+Synchromesh
Old Feb 24, 2011 | 04:18 PM
SDSilverM3's Avatar
I went ahead and ordered 5 quarts of the GMSFM fluid just to be on the safe side.
Old Feb 25, 2011 | 08:13 AM
Acutron's Avatar
Skillionare
So does any one know the range of VIN #'s with out the updated gear sets? Debating on whether or not I am going to take mine to the dealership. I even had issues engaging 1st gear this morning....W.......T.......F.........ACURA!!!!?!?! ?!?!?!
Old Feb 25, 2011 | 08:39 AM
^just do the juice..
its fairly cheap, and you wont have any down time taking your car to the dealer.
Old Feb 25, 2011 | 11:51 AM
SDSilverM3's Avatar
2008 TL with M/T – From VIN 19UUA75..8A000001 thru 19UUA75..8A029085
Give the juice a try and then go from there.
Old Feb 25, 2011 | 12:19 PM
Yonkers914's Avatar
04Tl
give the dealer a try it might be worth it. I did when my car had 80,000 miles and after a long conversation with them they replaced it and its been woorking great ever since still using the acura MT fluid. good luck.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
NitroViper
Mar 20, 2017 09:50 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
datadr
Sep 12, 2015 09:12 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
