3rd brake light removal?
Hey guys, sorry if this is a repost on this subject, I couldn't seem to find it anywhere.
Is there a trick to removing the 3rd brake light in the rear window? I have a bulb out and I want to replace it. I tugged on it a bit last night but it seemed pretty snug so I just wanted to check on the forum first before I use 'excessive' force.
There's alot of asian in
a clip? mine seem to be held together by glue and now it wont suck back up as it was before
i dont think my bulb is out but sometimes it get REAL BRIGHT as it suppose to be than dim sometimes when i hit the break..im guessing its the wiring or bulb must be bad?
06 TL 6spd. Navi/A-spec
Not sure about the TL but most third brake light bulbs are accessible through the top of the trunk area, first before you go pulling on the light from the inside of the car, i would open the trunk take off the top liner of the trunk and see if the bulb comes out that way. Most hondas third brake light bulbs are accessible at the top of the trunk (rear deck) and just twist out!
Kaa - Ching !!!
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
The 3rd brake light is at the top of the rear window................
It's secured with two white plastic clips and one metal clip..............should pop right off and not be glued....
The Third Brake Light on top of the rear window uses LED modules.
I would investigate a ground problem or loose wire if I were you.
Better yet, If it's still covered by warranty, take it to the dealer.
Originally Posted by donc
Take it back to the dealer....
Wild Child
Originally Posted by Xx06SickspdTlxX
I never noticed that on the tl! Most cars are located atop the rear deck.
Wild Child
I took it down myself and the dealer wanted $270.00 CAD for a replacement. :-( I could not believe my ears!!!!! I stuck it back in last night and it worked intermittently and it depends on how I brake with my paddle, the light comes on! I suspect the fault is at the moving part of the switch located close to the brake paddle. Anyone has any information on that? It is natural to take down the light to have it replace, but I suspect most of us having problem with it is not the LED light but the problem that I am having.
Head a da Family
Originally Posted by wildchild_8635
Thats the exact problem I am researching now. My friend has an 04' TL just like mine, and his brake lights only illuminate as bright as the park lights. (I hope that makes sense.) At first his was the only case I had seen, but I saw another instance where a TL had that problem and in both cases, the HIGH MOUNG LED was not on. Is this bound to happen to mine?
Could be the brake light switch. http://www.acura-cl.com/forums/showt...php?p=11938633
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
