3rd 4th pressure switch help :)
Old Jul 20, 2010 | 06:04 PM
Whdrms's Avatar
e92TL
Smile 3rd 4th pressure switch help :)
hey guys. i have 04 acura tl and it just hit 86k. car had no transmission problem, until recently it was kinda lagging? from shifting into 3rd gear 4th gear. i never changed atf on my car and im sure the previous owner 2 owners had never done so either. took it to shop and drained and filled honda atf today. i also mentioned acurazine to the mechanic about changing the pressure sensors and asked him to change it for me since i got em. he said he has never heard such thing and its better to leave functional old sensors and refused to change them T.T so... i wondering if theres aziner around my area who already has done this diy and is willing to help me out ofcourse i ll pay some cash and treat lunch or something lol. i live in nyc, queens, little neck
btw i was really hesitant about changing atf since it has high mileage and was never changed. the shifting habit is noticeably better than before, yet could need some more work. (swaping sensor and 2 more drain and fill atf) any suggestion or comments on what i did?
Old Jul 21, 2010 | 10:24 AM
myblack04tl's Avatar
I Hate Cars talks about it here:
https://acurazine.com/forums/showthr...ssion+problems
Some recommend you not use the Honda fluid and go with synthetic (Mobil 1/ Redline D4), if the fluid has never been changed you should do a 3X3 to get rid of old fluid and really introduce the new fluid. Others have different ways of doing the 3X3 with high mileage trans.
I have done the sensors and a 4X4 with my car using Redline D4, also changed my tranny filter. It was not hard but I have a lift in my garage
Old Jul 21, 2010 | 11:24 AM
AMUA6's Avatar
ScoobyZINE
With high mileage it might be wise to do a 1x3 (like you just did).. Drive it for a week or so, then do the 2x3 to finish it out. IIRC, I hate cars told me that.
Also, change the pressure switches after the full 3x3 (I think).
Old Jul 22, 2010 | 01:14 PM
Whdrms's Avatar
e92TL
yeah i thought it might do more bad than good to do full 3x3 first, bcus of that metal debris thing issue that i heard somewhere in acurazine...
anyways no body in my area who coul help me swapping sensors? im a no diy guy
Old Jul 22, 2010 | 03:10 PM
I hate cars's Avatar
It more than likely won't hurt a thing to do a complete 3x3. But if you have the option (DIY) to do a 1x3 first, I would do that.
Old Jul 22, 2010 | 05:35 PM
Whdrms's Avatar
e92TL
yea 1x3 is done already. im gonna do the rest 2x3 in about a month. most of all, i feel relieved to hear this actually from u, ihatecar. hey btw can u tell me how to change sensor. i read diy, and yet im. still like wtf..
Old Jul 22, 2010 | 10:45 PM
AMUA6's Avatar
ScoobyZINE
The DIY looks so complicated since you're viewing a picture on a screen. Once you get under the car and get to looking you'll be like oh wtf, this is easy. Trust me lol
Old Jul 23, 2010 | 12:15 AM
Whdrms's Avatar
e92TL
lol thanks.. im going to do it first thing in the morning... hopefully stock car lift is good enough for this job... i ll let u guys informed how it turns out
Old Jul 23, 2010 | 08:41 AM
AMUA6's Avatar
ScoobyZINE
Good luck
Old Jul 23, 2010 | 11:59 AM
Whdrms's Avatar
e92TL
ok... didnt know it was gonna rain here in nyc... but i managed to swap 4th pressure switch. As for the 3rd pressure switch, the bolt that was holding that black housing was stuck bad so couldnt do that one. i guess i ll ask my mechanic to do it for me when i go there for atf change next week or so -.- after the swap i took my tl for a drive, i felt the difference in 2nd gear to 3rd gear even though it shouldv been 3rd gear to 4th gear. Weird :/
Old Jul 23, 2010 | 02:52 PM
shadowkahn's Avatar
I just read through the other thread cover to cover again, and even though the question was asked many times, no one really answered it:
Should the pressure switches on '07's/'08's be changed as well, or do we not have to worry about it since we have the RL tranny?
Old Jul 23, 2010 | 03:57 PM
libert69's Avatar
18psi
^Senors are sensors regardless of year. They may be different for the new models but the basic principle still applies. The whole point of the 3rd and 4th sensors thread was to say that electronic sensors over time will begin to get slower which causes the lag in-between shifts. Just like your computer. Its fast outa the box but over the years it starts to slow down.
I would change the sensors on the newer models well. Put it this way, there is no way it can hurt but you may be saving yourself in the long run.
Old Jul 23, 2010 | 06:03 PM
Whdrms's Avatar
e92TL
^ +1. going to change my moms 03 mdx's sensor soon too
Old Jul 24, 2010 | 01:13 PM
MrHeeltoe's Avatar
Former Sponsor
Is this REALLY true? I am having a little trouble swallowing it. I guess I need to read IHC's post.
Old Jul 24, 2010 | 01:59 PM
libert69's Avatar
18psi
definitely read his post.
"What he said causes the issues are the two pressure sensors going bad slowly. To make a long story short, they reduce line pressure and control shift timing in order to provide soft shifts. When one or both start to go, line pressure falls and third starts slipping."
"What he said is that it starts slowing down and of course instead of failing on the high line pressure/hard shift side, it fails on the low line pressure/slip side. The ones that he showed me that had failed looked extremely clean."
He also said that when acura replaces a failed transmission they keep all the sensors that were originally on the car. This causes the next trans to fail over time as well.
Old Aug 4, 2010 | 11:34 AM
Whdrms's Avatar
e92TL
okk i finally changed 3rd switch today did 2x3 atf change today. (did 1x3 atf change and 4th pressure switch change 2 werks ago). i definately noticed the huge difference and i think the little jerking between 2nd an 3rd gear has disappeared. im soo happy i ve decided to change atf for my tl which considerably has high milage (86k). thanks azine !
Old Aug 5, 2010 | 09:57 AM
Majofo's Avatar
Here you go bud..
https://acurazine.com/forums/showthread.php?p=11747919
Old Aug 5, 2010 | 01:01 PM
jhumbo's Avatar
08 MDX, 04 TL (sold)
My exact experience. Thanks AZine! Thanks I_hate_cars!
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
