2nd gear issue. helppp
Old Aug 9, 2010 | 07:27 PM
joeyack722's Avatar
what up peeps i have a 08 tls 6spd wen shifting into second sometime i hear the gears grinding but it still goes in a little ruff sometime. what could it possibly be i plan on doing the gm fluid switch very soon can it be my clutch not engaging fully?
Old Aug 9, 2010 | 09:25 PM
SouthernBoy's Avatar
Registered Member
Either premature wear with the second gear synchronizers, clutch not disengaging completely, or driver error. Do a drain and fill using General Motors Synchromesh Friction Modified fluid, part #12377916, and report back your results.
BTW, if your clutch is failing to properly disengage, you would see problems in all of the gears.
Old Aug 10, 2010 | 02:27 AM
YeuEmMaiMai's Avatar
also take a sample of your fluid and have it analyzed for metal content. that will tell you what is up inside the trans
SidhuSaaB
May 30, 2020 12:40 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
RSpyder
Sep 30, 2015 12:46 AM
MikeJM310
Sep 24, 2015 07:24 PM
