2nd and 3rd gear synchronizer replace
Old Mar 5, 2011 | 10:35 PM
buchwheat's Avatar
Hi there, has anybody done the 2nd and 3rd gear synchronizer replace on an 07 tl-s. reason I ask is I'm having trouble shifting from 1st to 2nd and 3rd, even with the replacement of the fluid with GMSFM, it doesn't happen all the time, the dealer is willing to do the job under warranty, just curious what the expert in this forum think about this. thanks
Old Mar 5, 2011 | 11:55 PM
Nick337's Avatar
If they are going to do it under warranty jus let them do it!!!
Old Mar 6, 2011 | 12:27 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I wouldn't do it. I'd change the fluid to the miracle-working GM fluid. Several members have reported more problems, i.e., not being able to engage reverse, after having the stealer tear apart their tranny.
But the GM fluid? 100% success rate. 100%.
Old Mar 6, 2011 | 12:28 AM
https://acurazine.com/forums/3g-tl-problems-fixes-114/gm-synchromesh-transmission-fluid-friction-modified-621176/
Old Mar 6, 2011 | 06:33 AM
SilverJ's Avatar
OP said he already replaced it with the GM fluid. May need to lower that to 99.9 %
Old Mar 6, 2011 | 09:53 PM
SurfingScotty's Avatar
2007 6SMT Type-S
Same issue as OP'er. Any link to the specific GM fluid I should replace mine with?
Old Mar 6, 2011 | 10:42 PM
Bearcat94's Avatar
AZ Community Team
https://acurazine.com/forums/showthr...ht=synchromesh
Old Mar 7, 2011 | 09:28 AM
2007 6SMT Type-S
Thanks, Bearcat!
So I'm fairly mechanically inclined. Was going to change my oil, PS fluid, and the tranny fluid this week. Any tips on how to change the tranny fluid? I don't have an owner’s manual (yet). Is there any special tool I need (i.e.: fluid pump)?
Thanks!
Old Mar 7, 2011 | 09:51 AM
taoseno's Avatar
worked for us....................https://acurazine.com/forums/3g-tl-problems-fixes-114/07-type-s-6mt-dealer-has-agreed-replace-3rd-gear-per-tsb-799882/
Old Mar 7, 2011 | 11:05 AM
SouthernBoy's Avatar
Registered Member
Here's a link you might find informative. Read through it then make sure you read my post #39 and the links I listed there. Hope this helps you.
https://acurazine.com/forums/showthr...7#post12756307
Old Mar 7, 2011 | 01:15 PM
Majofo's Avatar
Old Mar 7, 2011 | 01:56 PM
I hate cars's Avatar
Also, if you're having trouble with that many gears it might be time to look at the pilot bearing. Does the car shift fine with the engine off?
Old Mar 7, 2011 | 10:54 PM
buchwheat's Avatar
yup the car shifts fine when the engine off, this problem does'nt happen all the time, could it be the cold weather,
Old Mar 8, 2011 | 12:34 AM
Could be but not that likely. Does it get better or go away after being driven for a while? Still leaning toward the pilot bearing.
Old Mar 8, 2011 | 07:00 AM
flyromeo3's Avatar
if it was the tranny. I presume they'd just replace it with a "remanufactored one" vs tearing it down?
Old Mar 8, 2011 | 09:06 PM
buchwheat's Avatar
I don't drive it long enough to notice the difference, I only drive the car to and from work which is 20 minutes maximum each way, some days it's ok smooth all the way even on cold days then sometimes it just catches the gears on second and little bit on third, I took it to the dealer last saturday, they took it for a drive and the guy said he did not see anything wrong with it but base on my complaints they will do the work base on the service bulletin which is changing the second and third gear synchronizer also they will change the clutch for me if I want to (just pay the parts) since they're taking down the transmission. Since I still have until the end of this year to decide (warranty) they will keep my case open and if I decided to have it done just give them a call.
Old Mar 8, 2011 | 09:39 PM
That sounds like the way to go. You might never find out what was causing the issue but you'll have it fixed and a new clutch for $250. The great thing is if I'm right and it's the pilot bearing, it's not going to be covered so you might come out ahead on this deal.
Old Mar 8, 2011 | 09:44 PM
Registered Member
Right. A failing pilot bearing can cause vibrations, difficulty in completing shifts, increased wear on synchronizers, damaged blocker rings, and be noisy.
As a rule of thumb, the release and pilot bearings should always be replaced when doing a clutch replacement job. These parts are not expensive at all and are wear items. By not advising the customer that these parts should be replaced, a shop is not doing a complete clutch replacement and not serving the best interests of that customer in my opinion.
Old Mar 9, 2011 | 08:45 AM
2007 6SMT Type-S
Well, I replaced mine with the GM stuff. So far, no more popping out of 3rd. Only put about 20 miles on it since I replaced the fluid but it used to do it once every 2-5 miles before so I think that's a good sign.
Old May 20, 2012 | 07:40 PM
TRINI-2-DE-BONE's Avatar
Talking 3rd gear sycro
My third gear is grinding. Where can I get it. Should I replace all 1 to 6
Old May 21, 2012 | 01:04 AM
gwiffer's Avatar
There's only a TSB for 3rd gear rough engagement/popouts and requires the replacement of the 3rd/4th gearset. Are they going to replace both gearsets (1st/2nd & 3rd/4th)?
Old May 23, 2012 | 12:31 PM
taoseno's Avatar
We had third gear synchro's replaced last year at Montano Acura in ABQ; they did a great job and no problems since then. Search my previous posts for details...........
Old Jun 8, 2012 | 03:22 PM
Acutron's Avatar
Skillionare
OP Just a heads up read my thread about having them tear up the transmission......
https://acurazine.com/forums/3g-tl-problems-fixes-114/need-some-help-2008-tl-s-859755/
cycdaniel
Dec 17, 2019 10:58 AM
asianspec
Cameras & Photography
34
Nov 4, 2019 11:11 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
Skirmich
Sep 15, 2015 06:41 PM
asahrts
Sep 4, 2015 05:55 PM
