2008 TL Timing belt snapped
Old Jul 29, 2024 | 10:22 AM
TL-'s Avatar
TL-
8th Gear
So my timing belt snapped, installed it few months ago so don't think it was an install error. I think it was just a defective belt.
I know the valves are bent, I'm wondering if I can get away with just replacing the valves or is it likely the valve seats need to replaced as well?
Also would you replace all valve or just just the ones that are bent, not sure if machine shop cost would be different but from a performance standpoint I'm wondering if it would matter?
Old Jul 29, 2024 | 11:04 AM
Where did you get the belt for future members reference to avoid
Old Jul 29, 2024 | 12:12 PM
TL-'s Avatar
TL-
8th Gear
It was in Honda packaging bought off eBay, so could likely have been a knockoff but it also could have been OEM, hard to know. I have not pulled the snapped belt yet to verify
Old Jul 29, 2024 | 03:17 PM
If interested, Go Power train has the below service available:
Old Jul 29, 2024 | 06:27 PM
TL-'s Avatar
TL-
8th Gear
Have you used their services before?
Old Jul 29, 2024 | 07:36 PM
619rcr's Avatar
I would just grab a used head from a junk car and swap it out. SOHC head w/ cam goes for around $100 in my area.
Also, hope you swapped the auto tensioner out with the belt. I prefer manual ones myself.
Old Jul 29, 2024 | 08:46 PM
No, not personally; however, Eric the Car Guy installed one of their automatic transmissions in his Honda Pilot and seemed impressed.
The salvage yard option, as mentioned above, is the preferable low cost alternative.
Good Luck.
Old Jul 29, 2024 | 09:48 PM
TL-'s Avatar
TL-
8th Gear
Good Luck.
There's hardly any salvage yards in the central US, it's not like California otherwise I would.
Old Jul 29, 2024 | 09:49 PM
TL-'s Avatar
TL-
8th Gear
I'm no stranger to timing belts and yeah I used OEM parts.
Car honestly ran better when it was boosted
Old Jul 29, 2024 | 09:54 PM
TL-'s Avatar
TL-
8th Gear
I take that back, there are some cars at a junkyard 90mins away. Thanks for the idea
Old Jul 30, 2024 | 07:01 AM
twokexlv6coupe's Avatar
If you're doing the valve job yourself, simply replacing the valves themselves are almost drop-in (plus some lapping), so it's pretty DIY-friendly. I'd also do the valve stem seals at the same time; might as well.
Doing the valve SEATS on the other hand.... is a much bigger job. You gotta press(??) the old ones out/new ones in, then I think need to be machined? Preferably multi-angle, so that needs to be brought to a machine shop, so there goes DIY.
Old Jul 30, 2024 | 11:06 PM
TL-'s Avatar
TL-
8th Gear
If the valve is bent, what are the chances that the seat is damaged? Anyone done a valve job following a timing belt snapping?
Old Aug 1, 2024 | 07:03 AM
Impossible to say for certain. Only way to know is to remove everything and inspect them.
From a SNAPPED timing belt? No.
From a timing belt install snafu.... yes, replaced 4 intake valves (and all 12 valve stem seals while I was at it), and that was it. Just lapped the valves into their old seats. Bingo bango bongo.
Old Aug 21, 2024 | 12:26 AM
bbsitum's Avatar
https://acurazine.com/forums/2g-tl-1...-again-999415/
sixwags78
Mar 26, 2024 11:51 PM
quantum7
Jul 30, 2018 07:51 AM
TACORICAN
Jun 12, 2014 05:17 PM
rdevillers
Feb 23, 2009 06:08 PM
TL-QT
Jul 21, 2001 03:12 PM
