2008 TL side mirrors
Old Oct 20, 2013 | 11:34 AM
TE-TYPE-S's Avatar
I got a 2008 TL Type S. Bought it a month ago. When i bought it, i think, when i put it in reverse bith mirrors used to tilt down. Now only one of them would tilt down, left or right if switch on L or R.
I just want to make sure, anyone else witj same model, does both your mirrors tilt down or just one at a time.? Just wondering.... Thanks.
Old Oct 20, 2013 | 03:18 PM
Will Y.'s Avatar
Registered but harmless
Only the exterior mirror you select will rotate down when the TL is put in reverse-- that's as designed.
You can put the switch in the center position so that neither mirror rotates down.
Owner's and Navigation manuals are available on-line through the 3G Service Dept./Garage at https://acurazine.com/forums/3g-tl-2004-2008-93/j-020-3g-acura-tl-owners-manual-navi-manual-warranty-booklet-pdfs-851625/.
Welcome to AZ.
Old Oct 20, 2013 | 06:10 PM
MarcoNorthPolo's Avatar
KCCO
^ What he said. Only one is designed to tilt down at a time. Whichever is selected by the button.
Old Oct 24, 2013 | 05:16 AM
[Blank]'s Avatar
i noticed my mirrors acting possessed as well but when put into park or even starting the car, the driver mirror will move up and click to past full scroll and continue to click. i found that if i set my seat and mirrors and then hit the save seat button and select 1 or 2(i chose 1, i never tried 2) it stopped. try that??
Old Oct 24, 2013 | 06:46 AM
^try that? he solved his problem.
your problem however is a dry tract. you'll need to grease the mirror tract.
Old Oct 24, 2013 | 11:02 AM
Acura604's Avatar
2024 RDX A SPEC
related topic...
my driver side mirror was on 'tilt down' mode when reversing...and so when I put the car in reverse, it did its thing...HOWEVER, once I put the car back into neutral (6MT), the mirror begin going up... BUT get this.. it didn't stop..it kept trying to go up and so it was pointed at the sky. I was like WTF... only happened once and haven't been able to duplicate it but odd thing that's for sure.
Old Oct 25, 2013 | 08:34 AM
^the tract or motor is going out. grease it!
Old Oct 26, 2013 | 07:39 PM
SycoCell121's Avatar
How?
rockyboy
Aug 4, 2024 10:35 AM
Type S Zero
Feb 17, 2016 02:37 PM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
