2008 TL automatic just got please help with problem
Old Jan 9, 2013 | 12:05 PM
shizzytheking's Avatar
Angry 2008 TL automatic just got please help with problem
Just took it to acura to replace a possible recall and I got a list of problems
I need some clarity and prices if possible
Says"both inner tie rod ends bad, Possible Rack front rear and side engine racks broken l/s comcompliance bushing broken, r/s ceacked drive belt tensioner loud, fluids dirty
I do notice a sound like others from the passenger side. My mpg is horrible my check engine came on a couple days ago
Are they saying my rack and pinion is done or is it control arm related?
Im assuming the engine racks they're referring to is motor mounts
What should I get done right away I wont be driving the car at all unless its like a 5 mile trip locally
Please help as to let me know my best route. What are the bushings and are they connected to the inner tie rods? Should I just replace one whole part or replace the ripped bushings All help is greatly appreciated
Old Jan 9, 2013 | 01:32 PM
nismopowerdqg's Avatar
LowNslowTL
those are all easy fixes. and most can be found in DIY section. Motor mounts on these cars go all the time so dont be alarmed. Go ahead and start with your suspension problems (tie rod ends) and your LCA bushings, get an alignment after that is complete and replace all your mounts at the same time dont do one at a time bc it puts unnessiary stress on the new mount when you do that. Also, the tensioner and drive belt can be done at the same time considering you have to take the belt off when doing the service, the tensioner is a bit of a pita to do IMO. Also just go ahead and change all your fluids. Take a step back and breathe bc these are just wear and tear parts and fixes that are common and will happen with age. No alarms necessary. Hope i covered everything. MAKE SURE YOU GET OEM HONDA/ACURA PARTS dont cheap out on any of these parts, they will make your life a living hell.
Old Jan 9, 2013 | 05:48 PM
dzionny_dzionassi's Avatar
how many miles on your tl?
Old Jan 9, 2013 | 07:43 PM
pohljm's Avatar
most importantly take it to an independent mechanic for second opinion and reduced prices. 2008? whats miles, warranty situation?
Old Jan 9, 2013 | 08:55 PM
Thx for the input its 112k on it just got it in nov and tryin to fix it before I sell it. Do I have to replace the tensioner they just said the belt. Itself was looking wore down. I probably do belt 1st then suspension and mounts followed by a tune up spark plugs and new fluids
Is that clicking sound the tie rods that I hear? And theres a clunking noise on the passenger side is that the torn boots bushings?
Old Jan 10, 2013 | 07:39 AM
LowNslowTL
clunking noise could also be the bad mounts.
Old May 22, 2013 | 12:14 PM
Im pretty sure the warranty is done its has 112k and the previous owner probably didn't extend anything as they treated this 08 TL like an 80 Civic
Old May 22, 2013 | 12:40 PM
Project_CLean's Avatar
MMkay.
First of all:. sucks that you bought that car without knowing how much money you're about to dump into it.
Second of all. All these things you mentioned are 'kind of' common and you can find more information about them by searching.
This is what i can decipher from your OP:
*Inner tie rod ends have significant play/movement. This could easily indicate a bad rack(some have had some issues with P/S racks, the one on my 3G leaks.) OR could simply be worn out inner tie rods. This would cause some clunking as well as some slack in the steering.
*Front/Side/Rear motor mounts is what they meant. these cars are NOTORIOUS for mounts breaking. You can read up on the issue around this forum.
*Compliance Bushing is broken..also VERY common. There's a thread, i dont even know how many pages long it is with people talking about the issue and their fixes. You pretty much have to replace them.
*Drive belt is cracked. Serpentine belt:replace it.
*Belt tensioner: not sure if they meant the serpentine belt tensioner or timing belt.Either way,replace it.
You're welcome.
Old Aug 22, 2013 | 09:17 AM
thanks
Old Aug 22, 2013 | 09:20 AM
JennyXO143's Avatar
6th Gear
I would be devastated
Sorry for your bad TL, these cars are usually very reliable.
Old Aug 23, 2013 | 10:51 AM
Acuraman101's Avatar
take you car to diff shop for sec opinion.
Old Oct 3, 2013 | 08:59 AM
not really devastated, you get what you pay for and I got the car for a good deal I should've just re-sold it months ago but i was lazy. Now its gotta go so I'll be getting the services done.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
